Buying a new motherboard, going to have to apply thermal paste. Duno what the hell im doing. Please help.
http://www.computerlounge.co.nz/components/componentlist.asp?parttypeid=113&t=3
This is my selection of thermal paste from the online shop im buying from. Any help would be greatly appreciated.
Please and thankyou. :)
https://linustechtips.com/topic/17269-thermal-grease/
MX4 will do it. Just a pea size dab on the CPU.
https://linustechtips.com/topic/17269-thermal-grease/#findComment-199185
MX4 is really good stuff.
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
https://linustechtips.com/topic/17269-thermal-grease/#findComment-199194
The MX4 is a good choice for your thermal paste.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/17269-thermal-grease/#findComment-199942
MX4, with a pea sized dot in the middle. The technique doesn't really matter, you just have to make sure you don't put too much on. You can either spread the paste yourself (not with your bare hands - preferably your index finger covered in some form of plastic) or let the heat sink do the spreading. I vote for the latter as I have found it to be the more consistent approach :)
https://linustechtips.com/topic/17269-thermal-grease/#findComment-199952
The Prolimatech will be the best performing thermal compound.
MX4 would also be good.
Intel Core I5 3570K @ 4.2Ghz w/ Hyper 212 EVO Gigabyte Z77X-UD3H 8GB Patriot Viper 3 1600Mhz CL9 Gigabyte Windforce 3X 7950 @ 1100/1550 Samsung 830 128GB Seagate Barracuda 1TB Fractal Design ​Define R4 Seasonic M12II 750Watt
https://linustechtips.com/topic/17269-thermal-grease/#findComment-202275
