So, I've just bought a 600 euro mining pc, but I also want to mine with my gaming setup. How do the Antminer U2 work? Do I just plug it in my gaming pc and they will mine for me meanwhile I'm gaming? And are they easy to setup?
I'm thinking on getting around 5 of them.
Best regards,
Noxz
Current Build Logs : ~ "The Future is Back" ~ "NES, The Little Beast" ~
z170l || i5-6600k || Noctua something cooler || 2x16gb ddr4 || msi 1050ti superlowprofile || hdplex 260w psu
https://linustechtips.com/topic/171112-coin-mining-start-help/
Best regards,
Noxz
I doubt you will ever make back the 600 euros that you spent.
The price of Bitcoin (and therefore other crypto currencies) was manipulated by Mt. Gox. You are never ever going to make back the money you spent.
https://linustechtips.com/topic/171112-coin-mining-start-help/#findComment-2273881
You will make about 0.04$ per day/per antminer u2. That's not taking power into account.
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
https://linustechtips.com/topic/171112-coin-mining-start-help/#findComment-2273919
Challange accepted.
https://linustechtips.com/topic/171112-coin-mining-start-help/#findComment-2274141
Do not buy the antminer U2, they are far to expensive per g/hash. They are nothing more than paperweights unless you can get them cheaper than $3 (even that price will soon be questionable)
Set up of the ASIC's can vary, it is more or less just plug and point mining software at them. It really depends how you have it connected to your main computer, usb, network, etc.
ASICs do not affect performance of the host device in anyway. This allows you to have manage ASICs using just a few raspberry pi's.
You keep using that word. I do not think it means what you think it means.
Users cannot, and will not securely manage key material. Most users can't and the ones that can, wont.
Ask me about Bitcoin, Litecoin, Crypto-Currencies, and/or Mining them.
https://linustechtips.com/topic/171112-coin-mining-start-help/#findComment-2274969
Best regards,
Noxz
Any little USB miners are a terrible value, just compare a Antminer U2 to an Antminer S1. The S1 gets 200GH overclocked, for $120 from Bitmaintech. The U2 gets 2GH, so unless you can find it for about $1.50....yeah......
Mining is dead.
Yup, just like PC gaming.
You are free, act like it~Warfairy. Moar guns. B) #3Dprinting
https://linustechtips.com/topic/171112-coin-mining-start-help/#findComment-2275329
I meant it was dead in the sense that its not worth it to get into it unless you already have gotten into it.
Diamond 5 in League :)
https://linustechtips.com/topic/171112-coin-mining-start-help/#findComment-2275333
Mining is far from dead. Using gen 1 hardware to mine does today not compete, or compare in anyway to the current gen 4 hardware that's just around the corner. 4 generations in less than 2 years, each with a massive efficiency, in speed, power consumption, and price over the previous.
I've said many times, mining is a zero-sum game over the long run. When you buy newer, and more efficient hardware what you put in, is roughly the same amount you hope to get out. It's not "free" money or a way to make an easy profit.
https://linustechtips.com/topic/171112-coin-mining-start-help/#findComment-2276262
Im not talking about a standard pc, I bought a pc that will give me an income on about 130 NOK aday, 15 euros. +/-. So after my calculations I will earn my 600 euros back in about a month. :)
https://linustechtips.com/topic/171112-coin-mining-start-help/#findComment-2278318
Markets on a very low low... in all honesty I'd almost just recommend buying 4 Radeon r9 290x on ebay and flashing them with stock bios then trying to rma them set up a BA gaming pc(maybe have it mine while you sleep) and if prices rise again switch to mining full time and have it then pay for it's self (use coins from the 290s to buy Asics to mine more coins)
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
https://linustechtips.com/topic/171112-coin-mining-start-help/#findComment-2299851
You won't make 600 euros in a month, no way no how. Set yourself up with some GPUs and go for a coin with lower difficulty and a decent future (can be hard to predict). With the purchase and electricity expeses if you don't stockpile a coin and wait for it to rise in demand and price than you'll be doing worthless calculations.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/171112-coin-mining-start-help/#findComment-2299953
