Best case for 30$.
Go to solution Solved by piggykid1,
Buy any case and use the cardboard box.
Anyways, try to find a Cooler Master ELITE 310 or a Bitfenix Merc Alpha. They should be around on Amazon.
I really wish that we'd just make organic hardware already, that grows and adapts to the demands it needs to meet. That way, grannies' computers can be floppy sacks of organicness and the 12 year old Minecrafters will look like the guys that only do bicep curls, and the nerdy programmers will finally have justice, with their body-builder rigs that skipped leg day.
CPU: i7-4770k 4.8GHz | Motherboard: Asus Maximus Hero | RAM: 16gigs 2133MHz | GPU: SLI Gigabyte OC 2gb 770's | Case: INWIN GRone | Storage: 1tb Blue, 60gb SSD | PSU: Silencer MK II 950w | Cooling: Modded H100i
https://linustechtips.com/topic/168028-best-case-for-30/#findComment-2235237
Spend a bit more--$40 and get a Fractal Design Core 1000 or NZXT Source 210.
I've also heard good things of Enermax Ostrog
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/168028-best-case-for-30/#findComment-2235245
I wouldnt say best case for $30 id say least worse :P
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/168028-best-case-for-30/#findComment-2235263
the case of a computer is the only part that is almost future proof. I'd be more likely to rip the motherboard tray out of an old case and set it on my desk for a build than to cheap out on a case.
fractal design core 1000 is the cheapest case I recommend.
https://linustechtips.com/topic/168028-best-case-for-30/#findComment-2235308
I would just spend the extra money or save for a little longer to get a better case. As said above it's the only thing you can really future proof with, you'll have it for decades and have many many different computers inside it. Better to spend the extra and get a good case for that than cheap out everytime you upgrade your entire system. They are worth the extra money.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/168028-best-case-for-30/#findComment-2235383
If your budget only allows for a $30 case i'd save up a bit more but thats just my opinion
|| MAELSTROM ||
https://linustechtips.com/topic/168028-best-case-for-30/#findComment-2235597
Core 1000. Definitely.
My PC: Intel Core i3-3220 | Alpenföhn Civetta | XFX HD 7770 1GB | ASRock B75-Pro3-M | Kingston HyperX Blu 8GB | beQuiet PurePower L8 430W | Seagate Barracuda 7200.14 1TB | Kingston V200+ 60GB | NZXT Vulcan | Soundblaster Play Replaced by Notebook + eGPU
My Notebook:   Apple MacBook Pro Retina 13-inch, Late 2013; Core i5 4258U @2.4-2.9 Ghz, 8GB RAM, 256GB PCIe SSD, Iris Graphics 5100 + GTX 960 eGPU
My Phone: OnePlus One with CM12      Camera: Nikon D3200 + 50mm f/1.8G + Kit lenses
https://linustechtips.com/topic/168028-best-case-for-30/#findComment-2236405
