https://linustechtips.com/topic/164978-help-with-gaming-pc-build/
I'd recommend an SSD.
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
It depends on what you're using it for, but either way, nope.
If it's for gaming, you really want to go Z97 unless you're running multiple GPU's AND other PCI-e cards.
If it's for a workstation, you'd really want 32GB of RAM as a minimum.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
Nope any system with 4820K is a waste of money... it performs 2-5% better than 4770K and for that you have to pay extra money on CPU, Motherboard and RAM... which is pointless. If you still want to buy LGA2011... go for 4930K, you will see definite improvements when compared to 4770K. Although, X99 and Haswell - E is just around the corner... and you will end up buying 1 generation older items.
If you want a "pre-built" gaming PC, you're better off going to www.ibuypower.com or www.cyberpowerpc.com than having someone over the internet build one, especially if you're willing to spend that kind of money.
Motherboard: ASUS P8Z68-V/GEN3 | CPU: Intel Core i5 2500k OC'd @ 4.5ghz | GPU: MSI N680GTX Twin Frozr 2GD5/OC | RAM: CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) | SDD: 120GB Samsung 840 EVO | HDD: 3 Western Digital 1TB  Hard Drives | PSU:Corsair Professional AX750 ATX12V & EPS12V Power Supply | Case: Corsair Carbide Series 300R Black Mid-Tower
USA
please do not post multiple threads. use the edit function in the original post if you need to correct something.
please read the COC if you have any questions or are confused about the rules of the forums.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
went HAM on this LOL
CPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  ($314.99 @ Amazon)
CPU Cooler:  Corsair H100i 77.0 CFM Liquid CPU Cooler  ($89.99 @ Best Buy)
Motherboard:  MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($157.99 @ Newegg)
Storage:  Samsung 840 EVO 250GB 2.5" Solid State Drive  ($134.99 @ Best Buy)
Storage:  Samsung 840 EVO 500GB 2.5" Solid State Drive  ($278.99 @ Amazon)
Video Card:  MSI GeForce GTX 780 Ti 3GB TWIN FROZR Video Card  ($633.98 @ Newegg)
Case:  NZXT Switch 810 (Black) ATX Full Tower Case  ($173.98 @ SuperBiiz)
Optical Drive:  Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($16.99 @ Newegg)
Operating System:  Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Keyboard:  Corsair Vengeance K95 Wired Gaming Keyboard  ($129.99 @ NCIX US)
Mouse:  Logitech G502 Wired Optical Mouse  ($79.99 @ Amazon)
Total: $2638.87
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-06-11 15:42 EDT-0400)
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
