Help on first $1000 build
Go to solution Solved by WoodenMarker,
Hi! It's been a long time since I've done my last build and i REALLY need some tips on this one.
The last time I built my own PC the top graphics card around was a GeForce FX 128MB GPU.
So, I'm planning to buy all of the parts in the US.
My budget is around US$1000.00.
The rig is intended tword gaming at high/ultra settings in 1080p,
I plan to upgrade the GPU in the next year or so.
Can u guys help me out?
Here is the part list.
http://pcpartpicker.com/user/felip3x/saved/gsx2FT
Thanks a bunch! :)
https://linustechtips.com/topic/164632-help-on-first-1000-build/
http://pcpartpicker.com/user/felip3x/saved/YJGxFT
Thanks a bunch! :)
i don't like it(just an opinion )
you don't need that much ram or psu wats
that being said you could grab a r9 280x or a gtx770
https://linustechtips.com/topic/164632-help-on-first-1000-build/#findComment-2190552
Dont go with 2 different ram moduals just get 4 x 4 of a kit or get 2x8's less problems
Dont need 4GB of vram for 1080p gaming
Other than that i doesnt look bad
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/164632-help-on-first-1000-build/#findComment-2190563
Don't buy 2 2x4 RAM modules. For gaming, all you need is 8Gb, unless you need it for video and photo editing or whatever. With you extra money you saved after taking off the RAM, get a little bit better of a graphics card, like a 760 or an R9 280, depends on what features you like.
EDIT: If you want more performance, wait for the release of Devil's Canyon and get an i5-4690k, and get yourself a nice Z97 board. These things are supposed to overclock really well, even on air cooling. It will be worth the wait.
Build: CPU: Intel Core i5 4690k | CPU Cooler: Hyper 212 Evo | Motherboard: MSI Z97 Gaming 5 | RAM: 8GB G-Skill Ares 1600Mhz CL9 | Storage: 120GB Samsung 840 Evo + WD Blue 1TB 64MB Cache + Seagate Barracuda 2TB 64MB Cache | GPU: MSI GTX 960 | Case: Cooler Master Storm Enforcer | Power Supply: EVGA 600B Non-Modular |
https://linustechtips.com/topic/164632-help-on-first-1000-build/#findComment-2190580
Let me whip up a build i did for a friend earlier this year , second
https://linustechtips.com/topic/164632-help-on-first-1000-build/#findComment-2190594
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($144.97 @ Amazon)
Motherboard:  Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  ($114.00 @ Newegg)
Memory:  G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory  ($82.99 @ Newegg)
Video Card:  XFX Radeon R9 280X 3GB Double Dissipation Video Card  ($259.99 @ NCIX US)
Total: $944.81
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-06-10 19:25 EDT-0400)
https://linustechtips.com/topic/164632-help-on-first-1000-build/#findComment-2190595
Total: $944.81
i like this one better
https://linustechtips.com/topic/164632-help-on-first-1000-build/#findComment-2190600
i just think its a bit low performance for the budget but you know check other threads
i personally got a gtx780 of a 1000 euro budget but depends on location
Euros != USD
1000 Euros = 1354.48 USD
https://linustechtips.com/topic/164632-help-on-first-1000-build/#findComment-2190603
http://ca.pcpartpicker.com/p/7ZjRkL heres what i did for my friend this includes a monitor
https://linustechtips.com/topic/164632-help-on-first-1000-build/#findComment-2190608
https://linustechtips.com/topic/164632-help-on-first-1000-build/#findComment-2190707
Will this dual slot graphics card fit the MOBO?
Yes, of course.
https://linustechtips.com/topic/164632-help-on-first-1000-build/#findComment-2198302
