Can i cut PSU cables?
Sam R
Can I cut some of the cables off a psu and just keep the molex?
I need them for fans
Thanks
You can just make sure you don't short them out and make sure you leave the power button ones working.
Thanks
Why would you have to cut the cables for that?
Yes, assuming you want to put the molex on to the fans properly you will need a soldering iron, unless you want to go the old twist and tape method> Just don't short anything out.
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
Thanks
I recommend against it, and just get a modular PSU. With a Modular PSU, you can just use the cables you need.
Gaming/Editing PC: AMD FX-8350 | CM Seidon 120V Liquid Cooler | Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard | G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600| Gigabyte GeForce GTX 770 2GB WINDFORCE | PNY XLR8 240GB SSD | Seagate Barracuda 2TB HDD | Corsair 600W ATX Semi-Modular PSU | Thermaltake Chaser A71 | LG 25UM64-S 25.0" 2560 x 1080 Display | CM Storm Devastator Gaming Keyboard & Mouse
