Hi,
I am planning my first PC build, I was thinking if the community could help with my parts and components with what i have chosen.
Processor- i5 4670K
Motherboard- MSI B85-G43
Graphics Card- Gigabyte Windforce OC Edition GTX 770
RAM- Kingston HyperX Beast 16GB 1866Mhz
Storage- WD Black 4TB
Samsung 840 EVO Series 128GB
Case- NZXT Guardian 921Mid Tower
PSU- Corsair CX500M
Cooler- Noctua NH-D14
https://linustechtips.com/topic/164040-pc-build-help/
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/164040-pc-build-help/#findComment-2182347
Change the board, but other than that it is good, looks pretty balanced.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/164040-pc-build-help/#findComment-2182353
whats the usage?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/164040-pc-build-help/#findComment-2182392
change out mobo to Z97 if you going with a K processor and go for a  1 or 2TB WD Black or Green.
also that NZXT case is really old design.  I wouldn't suggest buying and using that one.
maybe go with either a fractal design case or corsair case.  C70 Vengeance is a good corsair case for not much.
an RM series Modular PSU would be better.
8GB of DDR3 is all you need for gaming.  faster ram won't help in games. but really I tell people to buy the fastest 8GB kit their mobo has support for and that fits into their RAM budget.
https://linustechtips.com/topic/164040-pc-build-help/#findComment-2182515
For most gaming and general use system 8GB is more than enough memory.
Less expensive but good performance memory and hdd provide budget for a Z97 motherboard, nicer case, and better psu. There is no point in getting an unlocked (K) cpu and high performance cpu cooler if the system is not going to be overclocked.
Check out the H440 blue / black case, http://www.nzxt.com/product/detail/143-h440-performance-mid-tower.html. If that is not to your taste I would suggest something other than the Guardian 921.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($233.98 @ SuperBiiz)
CPU Cooler:  Noctua NH-D14 65.0 CFM CPU Cooler  ($64.99 @ NCIX US)
Motherboard:  ASRock Z97 PRO3 ATX LGA1150 Motherboard  ($99.99 @ Newegg)
Memory:  Kingston 8GB (2 x 4GB) DDR3-1866 Memory  ($69.99 @ Newegg)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Drive  ($84.98 @ OutletPC)
Storage:  Seagate Desktop HDD 4TB 3.5" 5900RPM Internal Hard Drive  ($147.99 @ Amazon)
Video Card:  Gigabyte GeForce GTX 770 2GB WINDFORCE Video Card  ($339.99 @ Newegg)
Case:  NZXT H440 (Blue/Black) ATX Mid Tower Case  ($129.99 @ NCIX US)
Power Supply:  SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.99 @ Amazon)
Total: $1240.89
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-06-09 15:25 EDT-0400)
https://linustechtips.com/topic/164040-pc-build-help/#findComment-2182836
