Will this help my temps?
Go to solution Solved by keskparane,
Good temp fix.
That tape will eventually fail and leave a mess.
I'd suggest something you can wrap around the case like string or elastic to hold temp panel in place.
Magnets might be a solution.
1 minute ago, Hinjima said:
Its not going to help your temperatures compared to having the sidepanel on the case.
Why not just use the case's sidepanel?
It shattered in my hands a while ago. Should have listened to those videos about not putting your pc on the floor.
I mean this should help the airflow right?
Thats unfortunate.
If you have enough fans it will help with airflow compared to no sidepanel 🙂
Good temp fix.
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
Bruh my PC fell on the floor glass panel first and it didn't break!
It got lose, some of the pins that hold the front panel broke thankfully not all of them, the pcie lever broke (just found it recently in the back of the case lol) and the PSU got a pretty big scuff, but all still works fine... 👀
What case is this and isn't a new side panel an option, maybe a metal one?
Sure, the cardboard will do but it's not really a permanent solution IMHO...
Sidenote: actually losing that pcie lever was a godsent, so much easier to switch out the GPU now! 🥹
PS: I have hardwood floor (oak) I think that helped a lot, it's not *that* hard, definitely dampens a bit (actually got it as a "PC appropriate floor" 😅 cause no static discharge and I hate carpet... Yikes)
-Scott Manley, 2021
1 hour ago, kerriya said:
Doing this to cool the 14700k
Yeah, I'd replace the case.
I have a strict no "trailer trash" motto at my house.
I know people are going to love your DIY-ness, and argue you can't see it anyway what's the big deal, but there is a huge benefit to having a home that isn't a mess.  Physiological impact alone would have me replacing it.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
For me biggest concern would be water/humidity, idk a cardboard case is kinda "cool" just not a permanent solution...
Btw the "trailer trash' solution reminded me that's how I have my speaker and controller cables attached (I just don't want the plugs wear out) and in that case some tape seems the best solution... I def need to replace it tho once in while...
-Scott Manley, 2021
2 hours ago, Blasty Blosty said:
Yes, it will be better than no side panel
Wait, sidepanels help with cooling? I run pure noctua fans (mostly 2000RPM 140s) and still find better temps without side panel.
Man, I get it. If you want that pristine look, go for it. But some of us enjoy the jugaar vibe. I still rock some wild DIY repairs because they Just Work and every time I notice them I smile.
As for long term, if you wanna rock this forever, no shade. But as others have pointed out, that tape will degrade remarkably quickly with the heat-cool cycles. You either want HVAC tape or even better get some thin plywood and bungee cord.
I suppose it depends on the case, in most cases leaving it on would be better as it keeps the designed airflow path, i.e cool air going over the components rather than escaping to the side
Console.WriteLine("Hello World!");
Fair, and I guess if the board has inadequate VRM cooling it could be necessary, but I've been running open case for a while and had better performance, better temps, and less noise with no noticeable reliability impact
I think your Noctua fans definitely play a part in that, I imagine the airflow is a lot stronger and more direct than some cheaper fans in a cheaper case
For my most recent build (rebuilt my main rig because mobo died) I actually ended up going with an OpenBenchV2 and it's loving the fresh air.
It's usually tempered glass.
I had a glass panel pop and shatter into many thousands of pieces by simply dropping it on the corner less than 1 inch off the concrete floor. That's all it took. 😞 The wrong amount of force in the wrong spot will lead to a complete disaster.
TBH, this is a feature of tempered glass, not a bug. Plate glass is just as likely to chip/crack, but when it does it turns a sheet into a myriad of razor blades. Tempered glass by contrast shatters into many tiny, largely dull pebbles.
EDIT: Okay, I'm wrong. Tempered glass isn't the same strength as plate glass. It's several times stronger. So we win coming and going!
My point is that glass is strong stuff...right up to the point it's not.
If you were to magnify concrete, you'll notice it's made up a teeny tiny rocks (like grains of sand or smaller). When the corner of glass hits just one of those grains, it's applying a shitload of force in a small area of glass. Once the fracture starts, it's a domino effect shattering the entire pane.
Yeah exactly it's stronger and safer.
Also strength is likely due to several factors, thickness, quality...
I mean I'm just surprised mine survived that, as the whole PC literally smashed onto it, not even a scuff... (unlike the PSU 👀)
-Scott Manley, 2021
