Hey guys I have a problem with my ram
I have 4x8 gb ddr4 3600 mhz ( I know I’m poor) Corsair vengeance ram but sadly when I try to run it even on 3200 or even 3000 mhz my pc doesn’t post or crashes. I ran fine for nearly 2 years but for the past year I have been fighting it sometimes even for weeks it’s fine other times I have to remove the ram to get the system to post. I even replaced my motherboard didn’t fix the issue. Got any ideas why it just sometimes decides to stop working
system specs
Cpu : Ryzen 7 5800x
gpu: rtx 3070
motherboard: b450 Msi gaming plus old one was a b450 thamahak msi
psu : 650 w Corsair gold I think
the fault is sometimes different but usually it’s : fault in non page area or something like that
I know it’s not a lot to go on
bios is on the newest version but I can’t afford a new pc
https://linustechtips.com/topic/1634969-ram-problem/
sounds like to (near) dead RAM to me, did you try every single RAM stick in the first slot and run it at the proper speed? maybe there's one stick faulty
                   -`                    y0ur5h4d0w@Darkness
                  .o+`                   -------------------
                 `ooo/                   OS: Arch Linux x86_64
                `+oooo:                  Host: Darkness
               `+oooooo:                 Kernel: Latest
               -+oooooo+:                Packages: Only what i need to keep it simple
             `/:-:++oooo+:               Shell: ZSH
            `/++++/+++++++:              Main Monitor: LG Ultragear LG 27GS85Q
           `/++++++++++++++:             Secondary Monitor: Asus MG28UQ
          `/+++ooooooooooooo/`           DE: Plasma Always Bleeding Edge
         ./ooosssso++osssssso+`          WM: kwin
        .oossssso-````/ossssss+`         Theme: Breeze-Dark [GTK2], Breeze [GTK3]
       -osssssso.      :ssssssso.        Icons: Breeze-dark [GTK2/3]
      :osssssss/        osssso+++.       Terminal: Kitty
     /ossssssss/        +ssssooo/-       Terminal Font: Noto Color Emoji 17 FreeMono 13
   `/ossssso+/:-        -:/+osssso+-     CPU: AMD Ryzen 7 9800X3D (16) @ 5.307GHz
  `+sso+:-`                 `.-/+oso:    GPU: AMD ATI Radeon RX 7800 XT
 `++:.                           `-/+/   GPU: AMD ATI Radeon Graphics
 .`                                 `/   Memory: 61830MiB
https://linustechtips.com/topic/1634969-ram-problem/#findComment-16883825
8 minutes ago, OHHwell said:
Yeah it work fine at the target speed it’s only when I use all 4 sticks together
did you try coupling them by 2? maybe there's an issue somewhere, so:
1-2
1-3
1-4
2-3
2-4
3-4
it's most likely a RAM sticks issue, i doubt it's an issue with the mobo because having 2 dead motherboards specially a newer one would be really "lucky"
https://linustechtips.com/topic/1634969-ram-problem/#findComment-16883828
Using more than two sticks can often be an issue at higher speeds. It's generally better to use 2x16, rather than 4x8 for that reason. You might need to lower speeds a bit to get it stable.
First thing to check would be if you're on the latest BIOS. Newer versions can sometimes improve compatibility.
https://linustechtips.com/topic/1634969-ram-problem/#findComment-16883829
1-2
1-3
1-4
2-3
2-4
3-4
I’ll try that later today maybe it fixit it if 2 motherboards dram slots died on me I must be the luckiest guy ever
https://linustechtips.com/topic/1634969-ram-problem/#findComment-16883830
Updated just a couple of weeks ago even running at 2133 still crashes it so either one of the slots is dead or it’s a timing issue but I am running out of ideas
https://linustechtips.com/topic/1634969-ram-problem/#findComment-16883832
for DDR5 i would agree, for DDR4 though i've never had issues with corsair vengeance 4x8 config, i could even overclock my sticks and having them stable over the years
@OHHwell check carefully BOTH the couples of sticks you have and compare the SKU. the SKU tells you the exact model and the timings/subtimings, you might have a slight mismatch in the timings that makes your PC crash.
https://linustechtips.com/topic/1634969-ram-problem/#findComment-16883833
Thanks I’ll look into it not at home right now
https://linustechtips.com/topic/1634969-ram-problem/#findComment-16883836
if they are the same there could be an issue somewhere else, i doubt it's in your windows system but at this point try a DISM run and then an SFC /scannow just to be sure
https://linustechtips.com/topic/1634969-ram-problem/#findComment-16883837
Yeah but was that hynix ones or samsung? The hynix ones are pretty bad generally, but it also depends on the BIOS rather than the CPU in my experience
(on my MSI b350 board it took like 3 or 4 years of updates to make them somewhat "stable" 👀)
-Scott Manley, 2021
https://linustechtips.com/topic/1634969-ram-problem/#findComment-16884090
  • 3 weeks later...
@y0ur5h4d0w  hey thanks for the suggestion checked the sku and they are different Cmw16gx4m2d3600c18  Cmw16gx4m2z3600c18 seems im not the only one with this problem looked on redit exact fault code seems like a problem with these models not working together well so will be selling the old one off and buying a mathching Z one
https://linustechtips.com/topic/1634969-ram-problem/#findComment-16890032
