I got this PC off Taobao and i feel like the fans aren't properly tuned.
When the fans are blowing hard i feel like there is a spot between bottom fans and gpu that are just recycling hot air. How should i go around troubleshooting it?
Here are my specs:
Ryzen R7 9700x
RTX 3080
DDR 5 6400mhz
750W psu
https://linustechtips.com/topic/1611147-too-many-fans/
Assuming these are all the same model of fan, I'd just install FanControl and bind them all to the same curve.
If they're oriented as expected (bottom+side intake, top+back exhaust), you'll have a slight positive pressure (which is usually good).
Nice looking piece btw.
I've gotten to know some stuff, but am far from omniscient, so don't take my advice as gospel and wait for other opinions - I just like throwing in my two cents when I can.
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721055
Here are my specs:
Ryzen R7 9700x
RTX 3080
DDR 5 6400mhz
750W psu
If those are standard fans (blow towards the hub/spider) then all of the fans are set to exhaust. Highly unbalanced.  Why do you think it is recycling hot air?
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721064
I would personally do this;
Start with setting up a bit more exhaust than intake, because it usually works the best IMO. Then slow all fans down in RPM. Run a light CPU and GPU benchmark, to get temps rising. Now set exhaust to a level that is comfortable in noise. Then start increase intake slowly, and check temps. This may require an hour or two maybe to get right but it is worth it.
I did this with my own build and found that if I flipped a single fan, my CPU temps dropped with 5-6c, while overall noise level dropped a tiny bit. GPU temps stayed the same.
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721066
It doesn't, that's a recipe for dust accumulation.
A bit more intake than exhaust is better, positive pressure (if the intakes are dust filtered)
I agree with @Blue4130 , it's unclear what kind of fans those are (intake or exhaust).
Edited by leclod
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721085
assuming the orientation of the fans is as usual, so the "free" part of the fans is where the fan itself "succ" the air
below is the diagram of what i belive it's happening, the white arrows are what i don't undersstand if it's hot air or fresh air but i assume it's wasted airflow or simply bad airflow
the colors are of tied to how hot the air SHOULD in theory be pulled by the fans
do you feel like this is correct? if so i think there's an issue with the bottom fans that are choking your GPU and i don't understand much about the usefulness of the back pointing fans, i've set them to orange and red but the bottom one it's probably white or orange because it pulls out some air from the GPU exhausts
PS: PLEASE DON'T HATE MY PAINT SKILLS lol
                   -`                    y0ur5h4d0w@Darkness
                  .o+`                   -------------------
                 `ooo/                   OS: Arch Linux x86_64
                `+oooo:                  Host: Darkness
               `+oooooo:                 Kernel: Latest
               -+oooooo+:                Packages: Only what i need to keep it simple
             `/:-:++oooo+:               Shell: ZSH
            `/++++/+++++++:              Main Monitor: LG Ultragear LG 27GS85Q
           `/++++++++++++++:             Secondary Monitor: Asus MG28UQ
          `/+++ooooooooooooo/`           DE: Plasma Always Bleeding Edge
         ./ooosssso++osssssso+`          WM: kwin
        .oossssso-````/ossssss+`         Theme: Breeze-Dark [GTK2], Breeze [GTK3]
       -osssssso.      :ssssssso.        Icons: Breeze-dark [GTK2/3]
      :osssssss/        osssso+++.       Terminal: Kitty
     /ossssssss/        +ssssooo/-       Terminal Font: Noto Color Emoji 17 FreeMono 13
   `/ossssso+/:-        -:/+osssso+-     CPU: AMD Ryzen 7 9800X3D (16) @ 5.307GHz
  `+sso+:-`                 `.-/+oso:    GPU: AMD ATI Radeon RX 7800 XT
 `++:.                           `-/+/   GPU: AMD ATI Radeon Graphics
 .`                                 `/   Memory: 61830MiB
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721092
Well okay, I thought simply of temperature, not of dust accumulation. But I still stand on my comment and would recommend this to OP.
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721094
Still, even without the dust argument I see no reason for rooting for negative pressure.
Care to explain ?
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721101
Care to explain ?
Well, dust filters are a thing and it is possible to clean a PC and the room it is in lol
From personal experience, a bit more exhaust have worked the best for me.
Edit: Alright, yup, seems like positive in general are better, from what I read. Sorry about that OP. Always done it like I said and have worked wonderfully for me.
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721102
Why would you "suck"  air from the GPU that desperately needs it with that bottom "exhaust"?
This is typically meant to be intake (with little effect but at least it doesn't hurt).
I agree, but what does "more" mean here? Like you usually have 2 or 3 front fans, 1 exhaust, that's positive pressure by design, it doesn't really matter if the exhaust runs "slightly" faster.
Of course the fishtank design of the PC in the op is a mess... Not saying it can't work, but so many turbulences and possible trapped air don't make me confident about it.
-Scott Manley, 2021
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721112
I see, sorry. Well, I've always had 2, maybe 3 filtered intake in front, then 3 exhaust - hence a tat more exhaust than intake. RPM of fans generally the same. Of course, not scientifically measured...
And yeah, the last few cases I've had had been these "cube" case, dual champer ones. Maybe that is why this works well for me.
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721113
than my assumptions are correct, the GPU is "choking" due to the exhaust and should be intake, however, if the PSU is right below that fan it will probably bring warm air (assuming there's enough space for air to be taken) to the GPU and i don't know if that fan will be useful at this point, i've never understood putting fans at the bottom specially on small cases like this one
other then this issue, the rest of the fans are actually correctly put, still don't understand why the fans pointing to the back of the case are there because i think they might be kinda useless but ok
many fans seems to be put for "look" more then actual usefulness
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721116
10 minutes ago, leclod said:
@y0ur5h4d0w @Mark Kaine part of those fans could (should) be reverse fans, no ?
It'd be nice if OP would show the same picture with the fans stopped.
yes they COULD be reverse fans but they look like normal fans to me, i don't think a taobao case comes with something "particular" however, hidden gems exists even on aliexpress if you have the patience to dig enough.
my diagram was very roughly made with my assumption but i think it might be how the fans are pointing at the moment
the case itself looks amazing honestly, kinda impractical but really really good looking
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721127
39 minutes ago, Blue4130 said:
This was a full system, not a case.
And Taobao has nearly everything that you can get from other (western) shops have.
good to know, i've never used it, i'll put taobao in the list of websites to surf besides aliexpress 😄
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721155
Do you live in China? If not, there is not much point. Ordering off taobao will be difficult to say the least. I guess that you don't have a Chinese bank account.
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721238
nope i'm from italy, i read thay are opening to western countries but i guess carefully digging aliexpress is the only way for now
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721253
I really don't see (or have heard) anything about taobao opening to western countries. It really seems like a China only thing. Temu, Shein and aliexpress all serve the west though. (for now)
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721320
I mean different tastes and all that, but if we're going by pure looks something like this would be hard to beat for me... The GOAT!
https://www.newegg.com/black-cooler-master-stacker-830-nvidia-edition-atx-full-tower/p/N82E16811119146?srsltid=AfmBOoom_qp_2e3wXElPIX3UBu1yvytTUNDsbBZZU_ZaN7r2tzEuN2uT
And cooling ain't too bad actually (after all it's meant to be an airflow case , probably still better than the taobao fishtank! 😅). (no offense)
-Scott Manley, 2021
https://linustechtips.com/topic/1611147-too-many-fans/#findComment-16721329
