Contact frame or not ?
Go to solution Solved by Dedayog,
8 minutes ago, gasolin said:
May have missed this section...
Asus + i9-13900K Thermal Results
I theorized that since Intel’s i9-13900K can run hotter than other LGA1700 chips, it should see more of a temperature improvement with Thermalright’s frame. So I installed it on Asus’ TUF Gaming Z690 Plus WIFI DDR5 motherboard, pairing it with DeepCool’s AG620 air cooler.
The results were utterly underwhelming; I didn’t see a difference in cooling effectiveness whatsoever. There wasn’t any problem with cooler contact to begin with in this configuration, and as such I didn’t see any improvement in temperature.
The temperature results of every single thermal scenario I tested here were, within margin of error, exactly the same. I was a bit disappointed with this result, because Intel’s i9-13900K can be difficult to keep cool in some scenarios
3 minutes ago, gasolin said:
Quick question
Do i need a contact frame for an i3 14100 ?
No.  Won't impact performance of that chip at all.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16717555
I got one on my 12400. I don't really need it but I like to have it.
It does improve the paste pattern.
Edited by leclod
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16717557
No. It might not even make a difference in the first place depending on luck, and best case scenarios you're saving a couple degrees celsisus which makes absolutely no difference for performance unless you're overclocking, especially on an i3. You're better off taking that 20$ and buying an i5 14400 instead of i3 and a contact frame.
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16717567
12 minutes ago, gasolin said:
it' the bending and accoring to toms hardware it does effect the temps
But with an i3, the temperature really doesn't matter unless it's up to 100C. It's not going to impact performance until it thermal throttles. And in that case, it's probably a case airflow or cooler issue more than something to fix with a contact frame.
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16717572
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16717660
24 minutes ago, gasolin said:
2025-05-0119_49_23-IsacontactframenecessaryforaLGA1700socketincombinationwiththeNHD15.jpg.b86d8cfaa91a1b2f808869ef774ce3c9.jpg
Experience tells my otherwise, my cpu was held in the Intel ILM first.
Since changing to contact frame I had to dismount it a few times and the paste pattern each time is smooth, unlike before.
To me the damage isn't done for good (even without the experience I'd doubt it, it seems obvious).
Edited by leclod
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16717668
  • 1 month later...
It seems super weird that Linus has not ever done a video on contact frames and give his opinion, especially since the lga 1700 socket launched several years ago. This seems to be an ongoing popular debate everywhere (here, Reddit, Tom's, YouTube). Most of the the other popular pc tech channels have covered it.
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16743321
The fact that it's been covered so much elsewhere is likely the reason LTT hasn't made a video. What more is there to say that hasn't been said?
If you're getting a high end recent Intel CPU (7 or 9 series), then using a contact frame can reduce temperatures by a meaningful amount. If you intend to overclock an i5 13600K, 14600K, or U5 245K, it can help there, too.
In all other situations, the benefits are negligible.
Are you hoping that Labs will find some unexpected results that every other outlet missed? Or that Linus will have a take that somehow shifts the general understanding of the products?
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16743460
I just find it odd for someone with his experience that he has never weighed in on it.  Not sure why you seem so critical of me asking. And not all the other sources say the same thing as you. Your opinion is different from many others I have seen, but it varies greatly with different builds. With all due respect, I would rather see his opinion than yours.
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16743816
Maybe you are affording Linus abilities and insight above other mere mortals. Why? he is just another guy.
chances are some folks on this forum may actually posses more knowledge than Linus.
Plus do you actually think the guy checks in on this forum to answer questions? C'mon, be realistic.
IMHO I like them aesthetically, they look a lot nicer than the stock solution.
One thing I have never heard mentioned and admittedly it is probably insignificant, BUT  considering these are a solid block of aluminum that are making contact around all sides of the CPU, aren't they acting as a passive heatsink as well?
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16743819
Just now, gasolin said:
I don't think they are close enough to where the heat is
they actually touch the cpu around all edges, heat radiates, if it's in contact, it's absorbing heat. simple physics.
the amount may be minimal, but it is still absorbing heat if it's in contact with the heat producing component.
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16743826
They're hidden under the cooler. lol. Unless you're type of person who likes to disassemble his pc occasionally just to get turned on by the aesthetic of a contract frame.
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16744494
Except they don't touch the heat producing part. They touch the substrate that the heat producing part is attached to.
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16744501
actually they contact the two "ears" and all around the outer edge of the IHS, not the PCB substrate
Oh, I see, like RGB junk inside a case when people spend most time looking at the monitor.
contact frames provide a cleaner looking, more secure solution.
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16745978
Are you sure? The pictures show that the rear of the frame is milled out where the ears and edge are.
Even if it does contact, the surface area in contact and the distance to where the heat in generated (the dies) will really limit how much heat is transfered. I would be shocked it if was more than a fraction of a degree.
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16746306
  Reveal hidden contents
TRUE, but  heat radiates and
in a world where folks stress over 5-10 FPS more and are more than willing to shell out mega $$$ for the bragging rights....
every little bit helps, even if we never actual see it aside from extreme benchmarks.
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16746310
1 minute ago, jmwhite33 said:
TRUE,
but in a world where folks stress over 5-10 FPS more and are more than willing to shell out mega $$$ for the bragging rights....
it's not like it's super expensive 10 euros dollars, not more than a tube of quality thermal paste
It's surpose to help with the retention arm that puts alot of pressure on the mb,cpu and can make it bend, a contact frame prevents it form happening
Im now on a 13600kf
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16746313
Im now on a 13600kf
I think it should become either the standard retention system or at least an option from the MOBO manufacturers.
It certainly is a better solution.
https://linustechtips.com/topic/1610636-contact-frame-or-not/#findComment-16746317
