Yeah, power limit is through the roof so the card only cares about temps and stability, let it stretch it's legs. It will draw 300W for the 90% of the time during load.
current PC:
PC configs I used before:
Did you wake up your computer from hibernation or sleep while having hwinfo running?
that is a wattage target.
it is likely just a mistake in driver development since it appears to be almost doubled or something.
the value you want to watch is TGP and TBP, those are real live values the card has acomplished
TBP Limit is the actual power target the card is trying to use.
finally amd has this level of sensor data also, took them long enough
6 hours ago, Neptun92ck said:
it's most likely 317w, though reviews have measured up to 450w, the 500-600w COULD be a split second spike, but not sure with new hardware.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
A transient spike of 2 times the power for a few miliseconds isn't unheard of. People forget that not so far back, the 3090s were tripping protections all over the place with 900W transient spikes on a GPU rated for 350W. So 600W for 307W rated board isn't great but isn't that bad either. Especially at launch. We all know that AMD drivers get better with time, so this will most likely be addressed pretty soon.
I guess these are numbers with RT enabled. Just curious, try to disable RT in the game and share the senseor data if possible. These RT units are hungry mofos.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
