How do radiators work?
Go to solution Solved by Shaqo_Wyn,
Yea but i kinda said i screwed through the fins so why isn't it causing a problem?
It's because there is no water flowing through the fins. Check out this pic. http://ferrell-pc.com/radiator.gif. Water flows through the pipes in the radiator and the heat is then transferred to the fins which supply the radiator with a much larger surface area that the fans extract heat from.
Noob here just wanna find out how exactly it is that radiators work. I have a water extreme 2.0 and was doing some cleaning in my rig yesterday and decided to change the config from push to pull to see if it could help with the dust. I started screwing through the wrong screws and by the time i noticed and took it out i realized i had threaded through a section of the fins. I panicked cause all else i have is the Intel box cooler and no more thermal compound on hand lol. Surprisingly when i looked at the other side i noticed that i wasn't a first time offender as the holes for the push configuration were threaded into the rad as well. So you get the idea of how my radiator looks like it went to war without a vest. surprisingly i have no leaks at all and my temps are normal still and I've had this for over a year and its had those threads through the rad for over a year now. I idle at about 35-40c and at load get up to about 80 when its really stressed.
Loves PC Games :D
https://linustechtips.com/topic/159882-how-do-radiators-work/
From what I understand much they're much like a cars radiator in that water is passed through fins of which airs is being passed over, the fins being made of a highly heat conducting metal, I assume, transfers the heat energy to the air moving passed and in turn cooling the water. For this reason the larger the surface area the more heat can be dispersed hence the huge radiators you can buy. However all this being said I have never water cooled a pc.
So I spelt something wrong in my post... I don't care I don't read through what I write and I type very quickly.
Intel 3770k stock, MSI Z77A-GD65, MSI GTX 760, Corsair Vengence DDR3 1600Mhz 16Gb, Corsair RM 550W, Samsung 830 256Gb, some random hdds.
https://linustechtips.com/topic/159882-how-do-radiators-work/#findComment-2129598
Loves PC Games :D
https://linustechtips.com/topic/159882-how-do-radiators-work/#findComment-2129604
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/159882-how-do-radiators-work/#findComment-2129609
Well there people have fixed that issue, I just have a lack of experience. Water does not pass through the fins.
https://linustechtips.com/topic/159882-how-do-radiators-work/#findComment-2129618
yea thanks man this looks more like it because i know i definitely tore some fins
Loves PC Games :D
https://linustechtips.com/topic/159882-how-do-radiators-work/#findComment-2129669
Water doesn't go through the fins themselves.
This is not a very accurate description of how computer radiators work. Water does go through the fins, but ONLY the larger/thicker ones that travel horizontally(they are not pipes, they are fins with water travelling through them). In between these fins/pipes there is a this sheet of metal that does a zig-zag to increase fin density. This is probably what you bent with your screws. You will not get any leaks unless you bend or puncture the thicker fins, which usually are strategically placed so that they are not under the screw holes.
https://linustechtips.com/topic/159882-how-do-radiators-work/#findComment-2129671
thats a car radiator though, a pc radiator only has one channel that goes around the fin array, not treu them like that picture
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/159882-how-do-radiators-work/#findComment-2129709
