Can I run BF3?
Solved by Sauron,
What FPS do you reckon I will get? Would it make it better if I were to get 8GB of RAM, or not by much? I've seen videos of BF3 running on low settings with Intel HD graphics 4600 and it doesn't look bad to the extent that I wouldn't enjoy it.
Hmmm, I'll have to get a job over the summer haha. Anyways thanks for the replies.
While I always recommend 8gb of ram, that's not the bottleneck on a system like that, it's the integrated gpu. FPSwise you should get 40ish fps at 720p, not very good but if you will get that gpu later it should be ok for a month or 2.
