Hello!
Newcomer here, I'm looking for guidance on internet issues...
For a month now, the internet will go down to 0mb/s on all devices for about 5s, then return to full speed.
I have called the ISP a lot, we have replaced the modem, problem persists.
They see nothing wrong in the settings.
The only solution they offer is to upgrade our modem Home Hub 4000/Giga Hub and increase our monthly payment by 7cad.
I feel like that's not the issue, I'm even using ethernet on my pc and I have these micro-outages 😞
Any help/comments?
https://linustechtips.com/topic/1583449-isp-issues-i-think/
A few things to consider:
- Bad ethernet/wireless drivers, though that would not impact all devices.
- Switching between 2.4 Ghz and 5 Ghz wifi (or better: disabling 5 entirely).
- Bad ethernet controller, like the highly problematic: Intel i225v.
- Certain types of traffic or malfunctioning device(s) that are causing the connection to reset.
- The connection from the cable to the house (e.g. bad socket), or the cable external to the house.
I would look at the event viewer to see what it says (if anything) about the disconnections, which might help you isolate the problem.
https://linustechtips.com/topic/1583449-isp-issues-i-think/#findComment-16528192
Got 4 instances of the "Intel(R) Wi-Fi 6E AX211 160MHz : Has determined that the network adapter is not functioning properly." would it point to a port problem?
https://linustechtips.com/topic/1583449-isp-issues-i-think/#findComment-16528197
Yeah, that looks like either a bugged driver or a dying interface.
Though it *could* be that your modem/router/wifi combo box is overheating. I actually had a similar problem even when I separated those three functions and it wasn't solved until I strapped a 120mm fan to the side of the modem and just blasted it with fresh air. Solved all my problems
Do you have the option to own your own modem?
https://linustechtips.com/topic/1583449-isp-issues-i-think/#findComment-16528206
Do the timestamps of those instances match the disconnections?
https://linustechtips.com/topic/1583449-isp-issues-i-think/#findComment-16528207
The overheating could be a thing... I kinda expected it to not be an issue but that would be really easy fix so I'll look into ventilation
"Yeah, that looks like either a bugged driver or a dying interface."
But like the network goes down right? like I imagine that I can't view the network's issues from event viewer?
"Do you have the option to own your own modem?"
Not with Bell afaik
https://linustechtips.com/topic/1583449-isp-issues-i-think/#findComment-16528209
Do you have a separate router, or is it an all in one unit (modem, router and access point [WI-FI])
https://linustechtips.com/topic/1583449-isp-issues-i-think/#findComment-16528212
1 minute ago, jpmercier said:
no, also would be a lot more entries than this
Yeah, I think I was wrong on the interface thing.
The combo box is dying. Either just being overloaded, or it's having an actual hardware fault. It's the ISP's property so they should be on the hook for replacing it, and free of cost. If they aren't willing to do that or not for free, ask if you can use your own equipment (often cheaper in the long run and almost always a better user experience
https://linustechtips.com/topic/1583449-isp-issues-i-think/#findComment-16528217
I do have a seperate router, the setup goes from:
Modem (Home Hub 3000) -> A random medium price D-Link router -> My PC
2 ethernet cables in this ofc ^
You experience outages even when using the wifi provided by the Modem
https://linustechtips.com/topic/1583449-isp-issues-i-think/#findComment-16528218
okay, I see, would you have any recs for good modems? (i'm not knowledgeable at all in this ;-; )
https://linustechtips.com/topic/1583449-isp-issues-i-think/#findComment-16528221
You shouldnt need the router in the middle then, as your Modem does all three jobs for you.
If you need more Ethernet ports than the provided modem has, you should get an Unmanaged switch to add more ethernet ports for your devices.
https://linustechtips.com/topic/1583449-isp-issues-i-think/#findComment-16528229
This is a Fiber ONT as well,, you're not replacing it with anything off the shelf. Your best bet is to troubleshoot the device alone and see if you have issues. If so maybe have Bell check the fiber line and go from there although I doubt it there is the small possibility of issues with the fiber that aren't enough to cause the link to go down fully.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1583449-isp-issues-i-think/#findComment-16528301
