I'm wanting to put a case above my desk/monitor. Looking at something like Thermaltake Core P3 ATX case (or similar) but want to rotate it 90 degrees, such that the IO/wires all come out of the bottom for easier hiding and routing down to my monitor/power.
Figure this also helps solve the GPU sagging issue (vs vertical mounting) as GPU is along its long axis in this orientation.
My question, is there any downsides to such a mod, are there any cases already designed with this concept (or wires to back when case is flush with a wall)?
Thank you!
https://linustechtips.com/topic/1583113-rotated-pc-case/
You'd still have gpu sagging, just 90 degrees the other way. To be honest, no matter what orientation, just get one of those lipstick GPU anti-sag brace, even if you place it on the cpu cooler I don't think it will matter much.
As for the whole pc being upside down, I don't think there should be any issues.
https://linustechtips.com/topic/1583113-rotated-pc-case/#findComment-16525442
VERY old pic (like mid 2010s) but here's my rig when I went wall mounted. It's cleaner to have a regular case and use some wire spiral wrap.
+1 for having a USB hub mounted under the desk, ~10 years later, I went mITX when Ryzen launched and PC is on my desk but I still use it
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
https://linustechtips.com/topic/1583113-rotated-pc-case/#findComment-16525449
Very nice setup.
Next level:  Run wires thru wall like for a fireplace mounted TV!    Should be a nice short run 5 feet up and down.  I mean, for those who wall mount still.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1583113-rotated-pc-case/#findComment-16525497
I know some old Silverstone cases used to have the wires coming out the top of the case.  So that's a company I'd look at for such a special request.  I have a Core P3 in my cupboard.  Here's what it looked like when it was deployed 🙂
It has a vesa 100x100 built in to the back of it so mounting it so the leads come out the bottom won't be a problem
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
https://linustechtips.com/topic/1583113-rotated-pc-case/#findComment-16525859
only case i can think of with cables out the bottom is the lian li v 3000plus
all other case have cables out the top.
i guess rethink on what you want i guess.
%E2%80%8BLIAN-LI-V3000-PLUS-Mode-2-Rotat
Edited by thrasher_565
https://linustechtips.com/topic/1583113-rotated-pc-case/#findComment-16526501
That's perfect, good to know, thank you. Also since you have it next to your monitor, what are is sound/noise like from it?
https://linustechtips.com/topic/1583113-rotated-pc-case/#findComment-16527821
It was tollerable.  Make sure you get the tempered glass though.  When I had the perspex side (all the early models came with perspex) it was a bit noisier
https://linustechtips.com/topic/1583113-rotated-pc-case/#findComment-16528059
