Hello!
Recently my dads work computer died and his boss gave me a 700$ budget to spend on a new pc
So he does jewelry design and im trying to build a pc that will be able to handle that without any problem
So the parts i have chosen are:
CPU: Intel Core i5-12400 Tray 12th Gen Processor - LGA 1700
Mobo: MSI PRO B760M-P DDR5 Motherboard
RAM: Kingston Fury Beast 16GB DDR5 RGB Desktop
Cooler: Thermalright Aqua Elite 120 V3 Liquid CPU Cooler ARGB Black
GPU : RTX 3070 8GB or RTX 3060 TI
Storage: Kingston 500GB NV2 M.2 2280 PCIe 4.0 x4 NVMe SSD
Case: XIGMATEK NYX Air Gaming Case
PSU: MSI MAG A600DN 600W 80 PLUS Non-Modular Power Supply
Please i would really appreciate if yall could help me adjust these parts
Thank you.
What programs does he use to do jewelry design? That would give a better idea of where to allocate budget. Also would be worth looking into some used stuff if you can convivence them. Can wrangle a more powerful setup then. Also country where you need to buy this stuff from.
34 minutes ago, mattw1029 said:
Hello!
Thank you.
specs of old work computer?
ddr5 is a waste of money if you arent going amd and arent going to have a minimum of 32gb (16gb kits perform worse than ddr4) alongside a decent hynix bin and not trash samsung/micron youll have to replace in a few years
id ditch the 3060ti and 3070 in favour of a 3060 assuming vram is more important than raw gpu power, otherwise used 3080 are ~350$ with used 3060 ~200$
aio is a waste of money and not very good for reliability just get a 36$ phantom spirit and itll outperform that 120mm not like thats needed for a 12400 or 12600k
and yes id get a 12600k alongside mobo swap to something like a z690m phantom gaming since those boards are dirt cheap and have better i/o than that b760 (10usb3 4usb2 for a total of 14 usba ports) alongside the bonus of beibg tunable if you want to do undervolts and whatnot for power efficiency
1 hour ago, mattw1029 said:
Hello!
Thank you.
Hello... If you are just trying to do simple Design Work then I recommend this AMD PC Build. If you must have an Intel/NVIDIA Build then look at the second Build below.
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
https://pcpartpicker.com/list/YDW3h3
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($116.82 @ Amazon)
Motherboard: MSI MAG B550 TOMAHAWK MAX WIFI ATX AM4 Motherboard  ($139.00 @ Amazon)
Memory: TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($50.99 @ Amazon)
Storage: TEAMGROUP MP44L 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($35.99 @ Amazon)
Video Card: XFX Speedster SWFT 210 Core Radeon RX 6650 XT 8 GB Video Card  ($219.99 @ Newegg Sellers)
Case: Montech XR ATX Mid Tower Case  ($63.90 @ Amazon)
Power Supply: MSI MAG A650GL 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($69.99 @ MSI)
Total: $696.68
https://pcpartpicker.com/list/mxwzqR
CPU: Intel Core i5-13400F 2.5 GHz 10-Core Processor  ($166.98 @ Amazon)
Motherboard: Gigabyte B760M GAMING PLUS WIFI DDR4 Micro ATX LGA1700 Motherboard  ($139.99 @ Newegg)
Memory: TEAMGROUP T-Force Vulcan Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($32.99 @ Amazon)
Video Card: MSI VENTUS 2X XS OC GeForce RTX 3050 8GB 8 GB Video Card  ($199.99 @ Amazon)
Total: $709.83
