Cooler Recommendation
Go to solution Solved by lol1419,
Sorry it took so long for me to reply, thanks for the help everyone. I measured my case and found enough room for a Hyper 212 Evo. I think at this time it would be my best bet with reasonable performance at a low price point. Once again thanks for everyone's help.
Hello and Greetings from Canada,
So I was planning to get a new CPU cooler as I want to move away from my old and loud stock cooler. However with only 3 fans ( PSU, CPU, and a 92mm rear exhaust) it's hard to think of a cooler that would be tailored to my case. I only have limited ventilation and no intakes requiring passive airflow from the front of my case. I want an all purpose CPU cooler and I don't plan to do any heavy overclocking except maybe only from Intel Turbo Boost. Any recommendations for a CPU cooler (air or liquid cooled) with a case that has limited air flow?
Please note that upgrading my case is not an option at this point in time, as a lack of funds would prevent me from doing so. In addition please keep in mind that I do not have a huge budget and the cheapest value to performance cooler would be best for me.
https://linustechtips.com/topic/15779-cooler-recommendation/
I been looking at those coolers for a while now. However are those viable solutions as I stated that my case has limited airflow?
That all depends on how much space you have on your motherboard and case.
In terms of a good, cheap, reliable cooler, the Hyper 212 is perfect.  The stock fan can just be a little noisy.
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-180332
+ 1 for the hyper 212 evo, excellent little cooler.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-180410
For your needs, the 212 evo is probably the best choice since it's the best bang for buck (it's $25 on newegg right now). However, if you're looking to overclock a little more, the XIGMATEK Dark Knight II would be a great option. It's about $45 and performs only 2-3 degrees worse than a corsair h80 watercooler so it is a great deal.
Cooler Master 212 Evo
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
Ads Removed
—Glenwing
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-180755
Get the Dark Knight II, amazing cooler, relatively inexpensive, and just looks awesome aswell.
Intel Core I5 3570K @ 4.2Ghz w/ Hyper 212 EVO Gigabyte Z77X-UD3H 8GB Patriot Viper 3 1600Mhz CL9 Gigabyte Windforce 3X 7950 @ 1100/1550 Samsung 830 128GB Seagate Barracuda 1TB Fractal Design ​Define R4 Seasonic M12II 750Watt
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-181206
Before you do anything, find out what the max allowable cooler height for your case is.  You can get this information from the manufacturer, or simply remove the stock cooler and measure from the CPU heat spreader to the case side.   This is critical.
Once you know that, can you tell us what your approximate budget is?  If you don't you'll likely just get a LOT of Hyper 212 recommendations, wand it isn't a bad cooler but might not be the best bang for your particular buck.
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-181274
If you can afford it and fit it in your case go for Noctua NH-D14  - build like a tank big and heavy but it has a  perfect mount. The back plate is super strong , you can`t bend it no matter what.
But the cooling is just :wub:  I am running 2500k@ 4.5ghz PASSIVE  on IT (around 40~45 degrees celsius)  for everything except gaming - so that is 70% of the time it makes NO noise - cant beat that even with water (gotta have a pump running)
If you are not planning to  OC  go with the NH-D14 and go passive it rocks.
ps: while gaming it reaches around 70 78 degrees celsius @4.5 ghz (passive) and like 38 - 45 with fans on .
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-181325
^ Depends allot on where you live.
My evo which is set to the lowest speed (no noise) all the time never goes above 35 while idle on my i5 2500k and never goes above 50 while on BF3 etc.
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-181563
Side Note:
Considering the reason you want to change your CPU cooler is that you want it to be quieter, have you considered using a program like speedfan or Asus Fan Xpert to limit the speed of your heatsink fan? or you can try limiting your cpu speed or undervolting to reduce the thermal output. Generally, if you have an intel processor with speed boost it is probably already doing this. While you are at it you can play around with some of your case fans if they are hooked upto your motherboard and vary their speeds. My stock cpu fan super quiet and rarely needs to exceed 50% fan speed even with terrible cooling, but I run my cpu until it is 75 degrees celsius. From saving your money by not replacing your CPU cooler, you can buy 100's of timbits. lol
My suggestion if you do need a new cpu cooler is the hyper 212 cooler. you can get it for approximately 30$ in most computer stores in Canada.
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-181699
If your case has a 92mm exhaust fan at the back, the chance of a hyper 212 fitting with the side panel closed is extremely slim. The same is true with most tower coolers. The low profile noctua cooler that was suggested by Unidentical over in your post in the liquid cooling forum is probably your best bet. The Noctua NH-L9i.
Corsair 900D | MSI MPower Max Z87 AC | i7-4790K @ 4.7Ghz | 1080 Ti SLI | 16GB Corsair Vengeance Pro 2400
XSPC Raystorm | EK-FC Nickel GPU block/backplate | 2x Alphacool UT60 480mm & XT45 240mm | 11x Linus Edition NF-F12
Schiit Modi/Magni 2 Uber | 5" KRK Rokit G3 | KRK 10S2 | Acer Predator X34 | Dell S2716DG
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-185601
Gelid Solutions GX-7 is worth considering
I have one really nice cooler that doesn't intrude on ram slots.
http://www.youtube.com/watch?v=MxfImHYxvGc
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-185616
Hyper 212 evo.
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-185984
If you're looking for something at around $30, the Hyper 212 Evo is the best. If you need something cheaper, the Hyper 212 Plus is AWESOME for about $10-$15 on sale.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-196861
Post a pick of your rig, so we can have a better understanding of the airflow inside your case, and space available :D
Main rig. Updated :D CPU: FX8350 @stock Cooler: Corsair h110 Motherboard: Ga-990fxa-ud5 Memory: Corsair Vengance 8Gigs 1866Mhz GPU: MSI GTX 970 SLI (blower cooler)  PSU: Cooler Master Silent pro 850w SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue Case: Thermaltake core V71 Fan controler: NZXT Sentry
Secondary PC: CPU: i5 4670k @stock Cooler: Thermaltake NIC L/31 Motherboard: Asus Z97I-PLUS Memory: Corsair Vengance 8Gigs 2133Mhz GPU: ZOTAC GTX 780 (Titan cooler) PSU: Antec 520m Pro SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue & WD 2TB Green Case: Thermaltake core V1
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-197120
  • 4 weeks later...
https://linustechtips.com/topic/15779-cooler-recommendation/#findComment-319905
