Ethernet cablecrimping questions
Solved by Needfuldoer,
6 minutes ago, Indian pc builder said:Ok, So I have a ethernet cable that I crimped myself and I was not able to get the exact order that It is supposed to be in, however, since technically just making sure that all the cables are connected to the same pins on both sides of the connection should work, that is what I did, however now my truenas scale server connected to these pins is only reading them as a 100baseT connection and not ad a gigabit connection, despite, the switch, router , and everything else being gigabit. any help on how to fix this?
Re-terminate the cable properly.
Ethernet uses balanced signals on the different pairs of wires, so putting the correct ones together absolutely does matter if you want the cable to perform as it should.
