budget?
low - CM Hyper evo 212
high- noctua NH-D15
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2094198
How quiet?
Where are you shopping/located? Budget? What case do you have?
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2094258
I fully recommend the be quiet! 3 Pro.
i second this
CPU: Intel core i7-4770 --- CPU Cooler: Corsair H105 --- GPU: Asus Geforce GTX 970 Strix --- MB: Asus Maximus VI Hero --- RAM: Corsair Vengeance Pro 16GB
Case: Corsair Obsidian 750D --- PSU: Corsair AX860i --- SSD: Seagate 120GB --- HDD: Seagate 2TB + Toshiba 1TB --- ODD: Asus External DVD-R
Keyboard: Razer Blackwidow 2013 Ultimate --- Mouse: Logitech G602 --- Mousepad: Corsair Vengeance MM600 --- Monitor: LG 29UM65
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2095456
My NZXT Havik 140 kept my FX8350 cool up to 4.4-4.5 GHz. My current Swiftech H220 keeps a 4.8GHZ 24/7 stable overclock. Using AS5 for TIM.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2095897
Have fixed noctual nh-d14 ! Will it be good ?
it is a very good cooler as all noctua products.
but check compatibility!
post your specs and i can tell you.
it would be even better to get the nh-d15.
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2099843
The D15 is not available in INDIA. I donno why I tried to search it a lot but wouldn't find it. I think it would go with AM3+ socket.
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2099852
that is true, but it needs to be compatible with case and ram.
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2099861
that should work.
tho it will be difficult to get the side panel on, the foam will touch it.
Yeah the case is Cooler Master Silencio 452 Mid Tower and ram is Gskill ripjaws
Edited by Rheinwasser
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2099914
that should work.
What about this would this go better i think it is more wider ! http://www.theitdepot.com/details-Cooler+Master+Silencio+352+Mid+Tower+Computer+Case+(SIL-352M-KKN1)_C5P21226.html
What do u think ? The ram will fit ?
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2100079
the link doesnt work for me.
if it is wider, its better. check the other dimensions fit as well.
the ram is not the problem with the case, ram and cooler is a problem and cooler and case is a problem.
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2100165
Would there a problem with ram and cooler ? I think it is since the front i/o is on the side
Just see if this works ! http://www.theitdepot.com/details-Cooler+Master+Silencio+352+Mid+Tower+Computer+Case+(SIL-352M-KKN1)_C5P21226.html
Try copying the whole link its not taking the full link address
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2100214
doesnt work.
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2104739
Here's a good ram compatibility list for the nh-d14: http://noctua.at/main.php?show=compatibility_ram_gen&products_id=34&lng=en
Also I'd recommend you to get aircooling and not water, I know you aren't the most experienced builder (no offense ofc) but aircoolers are RMA-free.
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2104782
Thanks again buddy...I am going with air cooler only.
https://linustechtips.com/topic/157132-cooling-fx-8350/#findComment-2104868
