I've bought a 3070 for my build and everything seems to be working but the GPU I have all the drivers and my PSU should be more than capable but sometimes it shuts down and says that there was a problem connecting the GPU or sometimes it doesn't say that and reboots with green lines. I'm just hoping I don't need to buy a new GPU.
https://linustechtips.com/topic/1570361-help-my-gpu-isnt-working/
Welcome to the forums!
Full specs of PC?
Did you try DDU?
What does Event Viewer show when the crash happens?
Is there a blue screen or does the pc just shut all the way down?
Full specs of PC?
Did you try DDU?
It has a a Ryzen 9 5950X
Gigabyte 3070
64G of DDR4 RAM
Corsair RM850e
and plenty of cooling
Just shuts down no crash log
Check your cables and connections.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
I did that after this post. Took it out took everything off has been fine since but I'm still looking into it in case it continues to happen. It happened again while typing this.
You *just* bought this card? I'd return and try again.
It's possible that the monitor is dying, and you should probably put in a different card and test to see if that is the case, but that return window is closing and this looks like a dying GPU.
I bought it used from a independent seller
1 hour ago, Gringoman420 said:
Rando
Its likely the seller sold you a bad card. It could maybe be your monitor like someone said above, but that screenshot seems like telltale GPU failure to me. What platform did you use to buy this? do you have a way to return it/get your money back?
It was FB marketplace so I'm SOL
