Is it worth upgrading my Ryzen 2700X for 1440p / 60fps gaming?
Solved by YoungBlade,
I would recommend first upgrading the GPU, then seeing how games feel. If you feel like the CPU is holding you back, you can always upgrade then.
While eventually 5800X3D and 5700X3D chips will go out of stock, I don't see that happening in the next few months, so you've got plenty of time to make a decision. Even then, you've got the used market after that happens.
Featured Topics
WarmEngine ·
Posted in Troubleshooting0 -
FormatAbuser ·
Posted in CPUs, Motherboards, and Memory4 -
Izume ·
Posted in CPUs, Motherboards, and Memory8 -
13
6
1
Mahbub ·
Posted in Peripherals3 -
Johnny Fehr ·
Posted in New Builds and Planning21 -
1
