Radiator fans as only intake?
Solved by Dedayog,
5 minutes ago, Venuly said:Im currently buying components for a new pc im building and in that pc im thinking about buying a 360mm radiator but the problem is my case cant fit a radiator at the top meaning that i have to put the radiator in the front of the case im wondering if itll affect my performance having the only intake fans in my case be through a radiator?
if you want to view my current components i will leave a link below
https://pcpartpicker.com/list/MTzct7
100% viable. Most people use a rad for exhaust or intake without other fans supporting that aspect.
