Easiest Way to Identify Storage Drives?
Go to solution Solved by Average Nerd,
1 hour ago, Discipulus1 said:
What is the easiest way to find out which letters have been assigned to which drives by the system?
Go into Task Manager, and check each drive. It should say the manufacturer and model on top of the activity graph:
I just completed a new build, using MSI Meg x570 Unify.  I have three M.2 storage drives populating slots on the motherboard.  I have one 2.5in SSD occupying a slot in my case.
Thanks!
Are the drives all the same size? Otherwise, you should be able to quickly see which drive is which by how large it is. If you open a disk's properties, the Hardware tab may also give you a hint.
English is not my first language, so please excuse any confusion or misunderstandings on my end.
I like to edit my posts a lot.
F@H-Stats
The Folding rig:
CPU: Core i7 4790K
RAM: 16 8GB (2x4GB) DDR3-1600
GPU 1: RTX 2070 Super
GPU 2: GTX 1060 3GB
PSU: Gigabyte P450B EVGA 600BR EVGA 750BR
OS: Windows 11 Home
Linux let me down.
Hello!
