RTX 4090 running @ PCIE x1 (1.0 - 4.0)
Solved by LylatDrift,
22 hours ago, DoctorNick said:Nice thank you for sharing! Should work now then. Makes sense that it could be an error with agesa or something, because manual states that M2A, M2B should work with GPU. Also didn't make any sense to me why It would run x1 and not x4/8
Evening!
Turned on PC and it's running PCIE x16 @ 4.0.
This might've been the fix.
I'm confident in saying that the recent AGESA updates seem to have caused some issue with the RTX 4090.
If anyone is reading this with the same issue, revert your BIOS AGESA to 1.0.0.7c.
