Is it ok to run 2 pwm fans from a single fan header using splitter?
Solved by RONOTHAN##,
5 minutes ago, EzioWar said:Hi, is it ok to run 2 pwm fans (mayb 2x fans on cpu cooler in push pull) from a single fan header using splitter?
Depends on the fan, but it's probably fine.
6 minutes ago, EzioWar said:is it harmfull in any way?
It can be if it overloads the header. Fan headers are rated for a certain amount of current (usually 1A, but there are some that are higher), and fans at full speed draw a certain amount of current (this will be printed on the fan hub and listed on the spec sheet). If you get a pair of fans that additively draw over an amp, it can burn out the fan header. However, unless you buy server fans, it's rare for a fan to draw over 1/3 an amp, so running even three fans on a header is usually safe.
