OS for use over serial port
8 hours ago, da na said:Unfortunately I have tried that with FreeDOS and... well, I assume it's booting, I hear the hard drive ticking for a bit after the bootloader runs from the onboard flash, but I get no output over a serial console session.
Machine 1, this will be our server: Install this Debian version to a hard drive and choose the XFCE desktop environment when it asks. After booting into the new Debian installation, install the openssh-server package. Edit the file /etc/ssh/sshd_config and change "#X11Forwarding no" to "X11Forwarding yes". Run "sudo service ssh restart".
Machinie 2, this will be our client: From a machine on the network also running Linux, install openssh-server and do the same edit to /etc/ssh/sshd_config and restart the ssh service, exactly like the first machine. Now from a terminal, remotely log into the first machine with "ssh -X <username>@<ipaddress>" which will give you a remote bash console. Now you can launch graphical programs and have them show up on the client machine. Last step obviously is to move the hard drive into the Cisco and try remotely logging into it.
