Please help! Are these good part choices?
Solved by DreamCat04,
13 minutes ago, Waxn said:And yes I do want an overkill aio
Why do you want an overkill AIO? It won't be much quieter than an air cooler and is much more likely to fail than an air cooler thanks to the pump being its weakest link. The 7600X won't draw more than 100W, 150W max if pushed.
15 minutes ago, Waxn said:Motherboard: Gigabyte X670 AORUS ELITE AX (rev. 1.0) ATX AM5 Motherboard ($249.99 @ Amazon)
You don't need an X670 motherboard for a 7600X, you'd be fine with a B650 board and save a few bucks
