What possible GPU's for 1440p
14 minutes ago, Mick T said:using a Samsung 4k QLED tv through a Denon AVR, no particular FPS, highest I can achieve, no mods
I'm going to assume by Antec WP500P Plus that you meant that Antec VP500P Plus. In that case, you should start by getting a new power supply. That one is in the E tier according to the PSU Cultists Tier List.
After that, honestly any current or last generation GPU that originally sold for more than $300 is more than enough.
The low-end for this would be the RX 6600 or RTX 3060 12GB.
Looking on PCPartPicker for Ireland, it looks like the RX 6600 is available for €261.90 at Computer Orbit. The RTX 3060 12GB is €307.95 at Paradigit.
For some reason in Ireland, AMD current generation cards are very overpriced compared to their Nvidia counterparts, so I would ignore the RX 7000 series - I don't see a single one where the price makes sense relative to the Nvidia competition. And anything above the RX 6650XT is sold out from last gen.
There is an RTX 4060 for €334.85 at Paradigit or an RTX 4070 for €602.95. Those look like the most reasonable deals for a new current gen card out of the ones I saw on PCPartPicker.
If you really want high end, the RTX 4080 Super at €1182.95 is an option. But it's completely overkill for your current CPU - for the games you play, you'd be entirely CPU bottlenecked with that card and see no benefit over the 4070. Even at 4K, I'm not sure it would make a difference.
