ram problems with ram upgrade
Solved by Tetras,
It looks like the chipset is H370, is that right? If so, it should support 16Gbit memory modules, but sometimes a BIOS update is required, so if you can I'd stick with 8Gbit (1Rx8) and either try to match what you have already (CPU-Z can tell you), or buy a new kit.
If you can't change memory frequency or use XMP in the BIOS (likely that you can't), then I'd stick with boring non-gaming memory (like Kingston configurator recommends) which will work at 2666.
If you buy gaming memory it may lack the profiles to support 2666 and could end up running slower than 2666.
