Building my first pc and i'm not sure which parts to pick
Budget (max 1100euros)
Country:Lithuania
Games, programs or workloads that it will be used for: gaming and some video editing,but mostly gaming and the games would be like gta 5 ,assetto corsa,cs2 and many more.
Other details here i'm going to include a pc that i want to build,but i'm not sure about the parts and maybe i could decrease the price somehow so it would fit my budget(1100euros Max).
I hope someone will guide me to picking the right parts with the right specs and a good price tag.I also would like to play on 165hz/240hz monitor from aoc.
https://pcpartpicker.com/list/ht4LxH
How are tech prices in Lithuania? EU can be more expensive than US parts 90% of the time, this list exceeds 1100€ in Germany for example.
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Ryzen 3 1200 3,5Ghz | 16GB 3200Mhz | B450 | GTX 1080 ti
Some of them are cheaper in Lithuania for example kingston 1 tb storage is in germany for 110 while in Lithuania it's from 60 to 80
What is your opinion on the parts could i change something so it'll reduce the price or maybe a better gpu for cheaper or the same price
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (€198.90 @ Galaxus)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (€54.62 @ Amazon Deutschland)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  (€162.99 @ notebooksbilliger.de)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€120.90 @ Galaxus)
Storage: Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€63.90 @ Amazon Deutschland)
Video Card: XFX Speedster SWFT 319 Radeon RX 6800 16 GB Video Card  (€387.90 @ Alza)
Case: Deepcool CC560 V2 ATX Mid Tower Case  (€59.90 @ Alza)
Power Supply: be quiet! System Power 10 750 W 80+ Bronze Certified ATX Power Supply  (€74.56 @ Galaxus)
Total: €1123.67
Generated by PCPartPicker 2024-03-25 20:36 CET+0100
this would be a good start, see all the changed parts
PC:
PCs I used before:
Country:Lithuania
Look for a 2x16GB DDR5-6000 CL30 memory kit. Perhaps https://pcpartpicker.com/product/cCKscf/silicon-power-value-gaming-32-gb-2-x-16-gb-ddr5-6000-cl30-memory-sp032gxlwu60afdeae.
Consider a case with a front panel USB-C port. Perhaps https://pcpartpicker.com/product/2MwmP6/montech-air-903-max-atx-mid-tower-case-air-903-max-b.
Total: €1123.67
I think the deepcool matrexx 55 mesh case is better because my friend has it and it seems alright because it includes 4x case fans
And the airflow seems better
560 also includes those:
I think regardless if you chose My 560, your case or @Why_Me's Montech, all of the cases have pre-installed fans and decent airflow,
(the all have mesh in the front, also both of mine and yours cases are from same manufacturer, why would one have better airflow?)
But the choice is yours,
PC:
PCs I used before:
Consider other options than Gigabyte EAGLE,
it has this Ethrenet connection:
While other MBs on B650 chipset should have this one:
PC:
PCs I used before:
is there any similar motherboards to that msi that are a little cheaper?
PC:
PCs I used before:
Also get 30CL RAM,
what other storages do you have there?
Teamgroup MP44L, WD Blue SN580 or SN570?
PC:
PCs I used before:
Add a case and video card to this build.
Motherboard
https://www.kaina24.lt/search?q=MSI+PRO+B650-S+WIFI
MSI PRO B650-S WIFI €166.00
CPU
https://www.kaina24.lt/p/amd-ryzen-5-7500f-100
AMD Ryzen 5 7500F €170.28
https://www.amd.com/en/products/cpu/amd-ryzen-5-7500f
CPU Cooler
https://www.kaina24.lt/search?q=endorfy+fortis+5
Endorfy Fortis 5 €53.12
https://endorfy.com/en/category/cooling-main/air-cooling/
RAM
https://www.elektrika.lv/lt/item/9644767
ADATA DDR5-6000 32GB (2x16GB) CL30 €123.32
https://electrobase.lv/lt/katalogas/ssd-m2/ssdlexarnm6202tbm2pcienvme3d-tlcwrite-speed-3000-mbytessecread-speed-3300
LEXAR NM620 2TB M.2 PCIe x4 Gen4 NVMe SSD €148,95
PSU
https://www.toppc.lt/c/73-maitinimo-blokai-psu/578218-gigabyte-p750gm-750w-80plus-gold
Gigabyte P750GM 750W 80+ Gold €82,31
54 minutes ago, podkall said:
Also get 30CL RAM,
Seagate, samsung, crucial
30 minutes ago, Why_Me said:
or use stock cooler if 7600
PC:
PCs I used before:
did I hear Samsung 1TB M.2 being affordable?
PC:
PCs I used before:
It's Samsung SSD 980 M.2 1TB and it's 91 eur
Not 980 Pro?
6 hours ago, brob said:
Not 980 Pro?
I'd honestly still take 980 over NV2
and the ones I listed are more or less expensive than the Samsung?
PC:
PCs I used before:
So would I. Just wanted to clarify.
Less expensive
2 minutes ago, Markz2023 said:
Less expensive
Alright, either will be decent, the Samsung isn't a huge step-up but to say it's slow would be lying too, the ones I mentioned are budget options that aren't lucky roulette of potentially sucking like the NV2 Kingston can.
PC:
PCs I used before:
40 minutes ago, Markz2023 said:
Less expensive
what does your build look like right now?
PC:
PCs I used before:
(if you changed pcpartpicker list, it changes link)
PC:
PCs I used before:
