k65 pro mini How Exactly Do Double PTB Double-Shot Keycaps Work And Is It As Simple As It Sounds?
Hot swap is usually referring to the switches. The key caps have always been "hot swap," meaning you can change them whenever you want. The keyboard can be plugged in when you are swapping key caps.
Most key caps follow the cherry mx stem, which ends in a cross hair pattern facing the user. This usually isn't the problem between keyboards and key caps, but do be aware some keyboards and caps are not compatible.
In addition to the physical connection, you also need to consider if the key cap set you want to buy has the right keys for the rows. Usually it is the bottom row that has the most incompatibility between keyboard manufacturers. The width of the keys are measured in "u" units. So each alphabet key is a 1u key, while the bottom row has 1.25u, 1.5u, 1.75u, or 6.25/7u (space bar) variants between all the keys. It's common for most custom key cap sets to come with a key in multiple sizes so that it can fit your keyboard. But it is also not uncommon to end up with a funky sized "shift" key in place of the Windows key. Just trying to warn you.
In the case of the links you've provided, the key caps are physically compatible with each other, but don't be surprised if you have an odd key on the bottom row.
It's also PBT, not PTB I have that set from Steel Series in white and it's actually a good set from a big name. Most of the time the big names are not as good as the boutique offerings like Drop DCX or GMK. It is definitely better than most of the cheaper sets from Amazon.
