Will there be any problems with this ssd?
JDP
It looks like the sticker is just pushed up from a chip in the middle of some kind. It's probably fine. The sticker has nothing to do with the functionality of the drive.
PC Specifications: Intel i9-14900KF, 5.9GHz all core locked, 5GHz ring, 1.45v Medium LLC, E-cores and HT disabled | MSI RTX 4090 Gaming X Trio | Arctic Liquid Freezer II 360 + Thermal Grizzly contact frame | 2x16 G.Skill Trident Z5 7400MHz 34-44-44-34 1T 1.45v (Tuned Subtimings, Hynix A-Die) | Gigabyte Z790 AORUS Elite AX | Windows 10 Home 64-Bit EVGA SuperNOVA 1000 T2 Phanteks P400A (Black non-rgb version, Phanteks T30 fans 3 intake (On AIO), 1 exhaust) | SK Hynix Platinum P41 2TB PCIE 4.0 (Boot drive), Samsung 870 EVO 2TB SATA
Displays: MSI MAG 271QPX 1440p 360Hz 27" QD-OLED | LG UltraGear 27GP950-B, 4K 144Hz (@120hz) 27" IPS
Desktop Audio: STAX SR-007 MK2 Electrostatic Headphones | STAX SRM-400S Amp | Schiit Bifrost 2/64 (NOS mode, USB in, XLR out)
Mobile Audio: Sennheiser IE 900 IEMs using included 4.4mm cable | FiiO KA13 "Desktop mode" Disabled
Peripherals: Razer Huntsman V2 Full size wired with linear optical switch | Logitech G502 Hero
Some stickers have a "warranty void if removed" but I don't see any on that one.
You can remove the sticker and perhaps get a heatsink onto it, if you notice any high temperatures.
It's only a pcie 3.0 drive so it probably doesn't need extra cooling.
It might void warranty still so I probably wouldn't try it.
