do i need cooling for my nmve?
david_croft98
Hey my lexar nm710 temperature is pretty high on load even with stock motherboard heatsink and thermal pad so do i need to buy separate heatsink for my nvme? p.s the manufacturer says operating temperature is 0°C to 70°C but mine is almost always over 70 when gaming or doing something that puts load on nvme idle is 50c
What motherboard + case are you using?
How is the overall system airflow?
What are your system specs?
I looked at your old posts, and I couldn't get any of that info.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
i have asus tuf gaming b650m-plus ryzen 5 7600 ddr5 32gb ram rx 6800 i have 6 fans in case which is deepcool cc560 my other one nvme is pretty chill max temp 50-55c airflow is pretty good all my other components at normal temp only this one nvme is high
Are running an air cooler or an AIO?
An air / tower cooler will help circulate around around the CPU and NVM SSD area...
Some motherboard's have a plastic film over the thermal pad on NVMe SSD heatsink.
Did your TUF B650 have any of that, and if so, did you remove it?
The review here shows the NM710 should run pretty cool for the most part. It's a pretty efficiency SSD.
https://www.techpowerup.com/review/lexar-nm710-1-tb/8.html
Otherwise, you may consider getting an aftermarket NVMe heatsink.
Make sure you get a good / decent one, though. Some of the crap on Amazon / Ali-Express are junk.
AMD Ryzen Rig
  • AMD R7-5800X
i have thermalright peerless assassin 120 se air cooler and yes i removed the plastic film from thermal pad guess my only choice is to get aftermarket heatsink well thanks for the info
gpus can exhaust its heat at the mb witch could be at the m.2. lower temos can improve things but i dont no just depends i guess. parts of m.2 dont like being too cold.
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
