Does upgrading my laptop from 16inch to 18inch makes major difference?
it has its benefits, I have a 17in msi and compared to my work laptops 15.6" it's definitely noticeable. It's an older one with either a 1440 or 1080 display (I don't remember at this point) and I find it's easier to use with having the text slightly larger and I prefer it playing games. I have had a 4k laptop from work and honestly hated it to the point I switched. The 4k made the text to hard to read and scaling didn't always help. For my personal laptop I love the larger screen, I just find it much easier to use and it helps most have a larger keyboard layout. The extra size can be a pain when you want to take it places, it wouldn't fit in my old backpack or rolling bag so I did have to get one that would fit the larger laptop. My Msi doesn't weigh any more then my other computers but some can get pretty heavy. I ended up buying a 14in hp probook that can play factorio and other lighter games, play movies, and do minor tasks that I can easily travel with.
聽
As others have suggested you could always get a monitor and plug it in but I find if im going to use my laptop it's on the couch, otherwise I use my desktop with an ultrawide.
聽
聽
TLDR: It's honestly personal choice, I prefer it for home use. Travel can be more difficult since most bags are designed around smaller computers. Weight difference isn't a huge difference but if you travel frequently you'll probably want a smaller and lighter computer. If it's occasional I really like the larger display, that little bit makes a big difference. Best thing I could recommend is find somewhere that has the screen size your wanting and try them side by side. After having a 17in MSI I won't go back, I have a 14in for taking places and my work laptop is a 15.6in and I don't like the screen size, I find it's much harder to work on.聽
