i have found the specs of the intel processors in the new surface pro 3
i3-4020Y, 2 cores/4 threads, 1.5ghz, no boost
i5-4300U, 2 cores/4 threads, 1,9ghz, boost of 2.9ghz
i7-4650U, 2 cores/4 threads, 1,8ghz, boost of 3.3ghz
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/156160-surface-pro-3-processors/
A 2 core costing 2000$. I'd rather buy a laptop for $1000 with a decent GPU and a 4 core CPU.
Yeah just carry it around in one hand like an ipad ><
You just cannot compare the 2. Sorry
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2081658
Already known for a while.
And you have an error, the 4650U is a 1.7GHz CPU: http://ark.intel.com/products/75114/Intel-Core-i7-4650U-Processor-4M-Cache-up-to-3_30-GHz
The Core i3 has a Intel HD 4200 graphics.
Core i5 has a HD 4400
and Core i7 has HD 5000
The CPU of the Core i5 is identical to the Surface Pro 2 revision 2
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2081924
Indeed, this is Microsoft trying to get a market share in weird tablet laptop things.
yup
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2081950
The i3/4gb ram/64gb storage model:  i3-4020Y Processor , running at 1.5 GHz, with Intel HD4200 graphics
The i5/4gb & 8gb ram/128gb & 256gb storage models: i5-4300U processor, running at a clock speed of 1.9 GHz and Turbo boost up to 2.9 GHz, with HD4400 graphics(same as the surface pro 2)
The i7/8gb/256gb & 512gb models: i7-4650U processor, running at a clock speed of 1.7 GHz with a maximum Turbo frequency of 3.3 GHz and HD5000 graphics.
The Surface Pro 3 has a 42 watt-hour battery which is a redesigned version from the pro 2 to fit the thinner pro 3.
Article:http://www.zdnet.com/which-cpus-will-you-find-in-the-surface-pro-3-7000029820/
Do any of the variations satisfy your wants in a high quality Windows 8.1 machine?
Also, talk about whether you like the idea of going with a Tablet for your portable daily driver. If you wouldn't want the Surface Pro 3 or any Surface what about one of the alternatvies? http://www.zdnet.com/7-good-windows-hybrids-that-rival-the-surface-pro-3-7000029699/#photo
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2083638
an i7 dual core with hyperthreading that runs at 3.3 while turbo'ing? thats pretty amazing imo
my school has a bunch of RT tables first gen, and if find them pretty good for a laptop replacement, only thing is that you cant really use it on your lap...
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2083654
I'm very much considering a Surface 3.
I do want a laptop, don't have one currently.
But the idea that it could also be used to write up notes and stuff in lectures, like with the pen not typed, seems really interesting to me.
I was looking at the i3 or the lowest i5. I figure an i3/4GB of RAM would be fine for note taking, youtube, web browsing.
Only worry I have is that free 30~GB of HDD space, and if that would be enough, or I could use the microSD to expand that further and it still be fast enough.
CPU: 6700k GPU: Zotac RTX 2070 S RAM: 16GB 3200MHz  SSD: 2x1TB M.2  Case: DAN Case A4
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2083730
It's not HDD its flash storage. Kinda like SSD. Also, you can use a Micro SD card I believe up to 128gb. Also, just save documents, photos or what ever you want saved in OneDrive so that you can access them anywhere.
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2084246
Don't really get the point of getting anything above an i3 if u just get a clock speed boost and not more cores or threads kinda disappointed thought the i7 would be Atleast a quadcore for the price :/
There is DEF a performance boast going from the i3 to i5 to i7. Plus the i7 has hyperthreading and you get better graphics as you go up. Also, most laptops actually are dual cores anyway but some are quad cores.
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2084257
Ah Doh, I did know it was Flash based storage, must have been on auto pilot.
And yeah, thats what I was considering, using the 30~ for programs only and then using a mix of a MicroSD, OneDrive, DropBox and my NAS for any further storage needs.
Will make a decision based on price most likely, its going to be nearer the end of the year before I'll be in a position to buy one, so I guess atleast I will be able to see far more reviews and whatnot.
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2084274
No they all have the same amount of threads also for an i7 I would expect it to have a quad core since a lot of laptops have them and graphics boost not really anything to care about its intergrated and a tablet your not going to be playing AAA titles on this.
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2084452
These are the ULV chips, you get the same if you buy an ultrabook and, honestly, if all you do is browsing and some office work they're excellent.
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2085154
I was hoping I could hook the I7 variant up to an external gpu (which has been ruined by no thunderbolt) and replace my desktop. Oh well. I'm not sure the I7 had the horsepower I would want anyways.
Daily Driver:
Case: Red Prodigy CPU: i5 3570K @ 4.3 GHZ GPU: Powercolor PCS+ 290x @1100 mhz MOBO: Asus P8Z77-I CPU Cooler: NZXT x40 RAM: 8GB 2133mhz AMD Gamer series Storage: A 1TB WD Blue, a 500GB WD Blue, a Samsung 840 EVO 250GB
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2085718
A FX 6300 has more cores and more threads then an i5 4670k YET the i5 def beats it. I think you need to understand that performance isn't just about cores/threads/speed in the processor world.
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2086332
Wtf are u on about I never said that I know that wtf I'm talking about the specific INTEL chips inside the surface are all nearly the same just with a clock boost and better igpu and that makes no sense at all u are comparing 2 completely different architectures then saying the same goes for chips with the same architecture so by your logic there is nothing better than an i3 lol
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2086996
That i7 model must purr.  I imagine it will even run some games modestly well (i.e. not at 1440p resolution unless they're super simple).  How many games have good touchscreen support, though?
ExMachina (2016-Present) i7-6700k/GTX970/32GB RAM/250GB SSD
Picard II (2015-Present) Surface Pro 4 i5-6300U/8GB RAM/256GB SSD
LlamaBox (2014-Present) i7-4790k/GTX 980Ti/16GB RAM/500GB SSD/Asus ROG Swift
Kronos (2009-2014) i7-920/GTX680/12GB RAM/120GB SSD
https://linustechtips.com/topic/156160-surface-pro-3-processors/#findComment-2087036
