240 Direct Die Water Cooling Solutions
3 hours ago, SUPR3M3 OM3G4 said:No no, I'm not聽
I had that case back when I didn't travel and was working from home at a single location.
It's just the old case I had before this one.
Just wanted to share for clarity.聽
I'm currently traveling with and have my PC built into a Lian Li A4-H20.
Yes, my work does require a GPU聽
聽
Sticking to a AIO is probably best since I wouldn't doubt if you happen to run into a TSA agent at some point who questions what fluid is inside of a custom loop. The factory nature of an AIO might give protection from that. Unless you can guarantee the loop is <3.4oz since that appears to be the limit. If you're never flying to-from the US, then that might not be a problem.
聽
There's also the potential for damage if you're direct die mounting, since there's no longer the material buffer between the die and mass of a waterblock. If you haven't installed a contact frame yet I'd just do that and stick to the 240mm you're using currently.
聽
If you're needing more performance, consider getting crazier fans for the AIO and/or ensure they're ducted through the radiator (taping off the gaps between the fan+radiator) then having a 'jet engine' mode for the fans.
