Inverted ATX Airflow? 🌡 My Toes are Cold 💨🥶
20 minutes ago, G4M1NGPCR0CKZ said:Hey Forum,
I'm trying to plan out a Case-Swap into the Seasonic Syncro Q704 Inverted ATX Layout Case, I'm thinking of running 6x 140mm intake fans, 3x BeQuiet Silent Wing 4 Pro 140mm in the top blowing Downward onto my XFX Speedster Merc 319 Radeon RX 6950 XT, 3x Arctic P14 RGB in the front + mounting my 280mm BeQuiet Pure Loop AiO onto 2 of the Arctic fans for Push with another 2x BeQuiet Silent Wing 4 Pro 140mm fans in Pull configuration. For exhaust I have 1 more Arctic P14 RGB in the Rear towards the PSU shroud, and I'm going to be mounting the ATX Power Supply with the fan exhausting the inside of the case blowing out the rear, and a single Arctic P12 RGB 120mm fan exhausting Downward on top of the PSU shroud.
P.S. My Feet get cold easily and this will be located under my desk, also Seasonic graciously provides magnetic dust filters for the top and front of the Syncro Q704
If it's under a desk a$$ to the wall you'd better also inverting the airflow !
Rear intake, Top intake with the rad (to not block air exhaust if put front), Bottom intake, and front exhaust
That's my setup (with no bottom fans), my PC is pretty enclosed in a niche under my desk, and it works pretty well, maybe only 3C or so more than a standard airflow on a desk
I added dust filter rear and top to avoid dust buildup, as I also have 3 hairy cats !
