frame generation AMD - A bit lost on Frame Generation and Input Lag
34 minutes ago, ie-techtip said:Hey, that makes sense. However what I don't get then is... when it is ideal to use Frame Generation?
When you're playing a single player game that is not latency sensitive and you are well below your monitor's maximum refresh rate. Say you have a 144 Hz monitor and the game runs at ~70 fps without frame gen. In that case frame gen can get you close to 144 fps. That's basically the only use case where it can make sense.
20 minutes ago, ie-techtip said:Since I don't need to enable Frame Generation if I don't want to, avoiding issues with input lag, etc. My question was more like... if I have a 60hz monitor and I get 120FPS without Frame Generation, am I getting a benefit in terms of input lag by going to 200FPS thanks to Frame Generation together with AMD Anti-lag?
No. The additional frames produces by frame generation do not increase the game's actual performance. They are generated purely on the GPU. Which means the engine's frame rate is still whatever it was before you enabled FG and the input lag for in-engine frames is exactly the same as before. There is zero benefit to input latency by enabling frame generation.
The only possible benefit is from anti-lag, which you can enable separately. The reason you want anti-lag with frame generation is to mitigate some of its increase in latency. But if you simply enable anti-lag on its own, it results in a net-benefit, rather than a simple reduction of a drawback.
Say you have 20 ms input latency normally. Let's say enabling frame generation increases that to 40 ms (20 ms lag between input and frame getting rendered, then 20 additional ms before you see the frame).
Thanks to anti-lag it might go down to 35 ms (15+20 ms), mitigating some of its drawback. But if you had simply enabled anti-lag on its own, you might go down to 15 ms instead.
