High CFM rgb fan
AnonimBBOOSS700
Hi! I am looking for a high cfm fan with rgb. So is there a good option for a high cfm rgb fan??
pick what you want:
A ton of RGB or a really HQ Fan with high CFM.
(Or be a spoiler and get an epic fan, and tack on a Phanteks Halo (Lux) to it.)
a halo on w/e fan tou want will be the best.
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
kinda need a white fan for that to look good, and none of the good ones are white 😮
there are no hi rpm white fan. probly best is like 2k rpm i would guess.
3kish for the hier tire pc fans but theres more hire rpm fans then that like 10k fans... and thow are like server fans...
still wating for a price drop for bquiet wings 4 140mm fans. i got a 120mm for $25... but compared to the thrmalright 120mm fan and 140mm fan its not much better... and cost almost duble...
the best is the t30 but i have not goten one yet there on sale atm for $100 for 3 still bit hi...
Edited by thrasher_565
not even 2k 😕
5 minutes ago, NorKris said:
not even 2k 😕
i think lian li has white fans 30mm but they sell em with the aio....🤷‍♂️
