need help fixing my atx case
Solved by thrasher_565,
i mean i guess there probly some metal body fillter that you might be able to build it up then sand it down. but i mean its a $10 case thats been used...
some case had sidepanals the just sucked.
Featured Topics
CloseTheDoor ·
Posted in New Builds and Planning1 -
pchelp ·
Posted in CPUs, Motherboards, and Memory4 -
pontikos ·
Posted in Troubleshooting2 -
5
wolfgangam ·
Posted in Windows3 -
9
3
