Avid gamer and multi-tasker... My first PC build.
This is big budget; I have never splurged like this before in my life... so I don't have the budget to make a big mistake.
Budget 3500$ - 9000$ 40 000 NOK - 100 000NOK:
Country: Norway
Games, programs or workloads that it will be used for: Modern games with max fidelity-settings, workstation programs (Fution360, Unreal 5, blender, ai/procedural networks/genetic algorithms). When I get VR-glasses I would play Rumble and Minecraft ray-traced.
Other details: I use 6 monitors and have gotten dependent on that. I have peripherals and will be using the system for 50+ hours a week.
Due to stability issues in my old system I am a bit paranoid for stability. 3440x1440 175hz main monitor + 5x 1920x1080 (I would desire my 99% fps to be over 200fps). No peripherals needed, I have no system; I have a single 1TB SDD. I am fairly sure I need a 4090, so I intend use the 4090 ¿only? for my main monitor, and supplement my other monitors with an arch GPU and perhaps a second hand GPU? So I don't know if a second system to go with the main is a good or better option; given my budget.
Intel Arc for encode? I heard it is a good value proposition.
I would love to use the snowblind case for PC-stats weather and to-do list. I believe my CPU and GPU is good, and I know nothing about RAM and storage differences...
https://www.ibuypower.com/gaming-pcs/signatures/snowblind
https://pcpartpicker.com/list/hJgZPF
CPU - AMD Ryzen 9 7950X3D 4.2 GHz 16-Core Processor
CPU Cooler - Cooler Master MasterLiquid Lite 240 66.7 CFM Liquid CPU Cooler
Motherboard - ASRock X670E PG Lightning ATX AM5 Motherboard
Storage - Samsung 990 Pro 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Video Card - Intel Limited Edition Arc A750 8 GB Video Card
Video Card - MSI SUPRIM LIQUID GeForce RTX 4090 24 GB Video Card
Case - Lian Li O11 Dynamic EVO ATX Mid Tower Case
Power Supply - SeaSonic PRIME PX-1600 ATX 3.0 1600 W 80+ Platinum Certified Fully Modular ATX Power Supply
Case Fan - Noctua F12 PWM 54.97 CFM 120 mm Fan
Much thanks
Country: Norway
Much thanks
For 40000 NOK
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (kr4589.00 @ Proshop)
CPU Cooler: ARCTIC Liquid Freezer III A-RGB 48.82 CFM Liquid CPU Cooler  (kr1049.00 @ Proshop)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  (kr2319.00 @ Proshop)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (kr1588.00 @ Proshop)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (kr2032.00 @ Proshop)
Video Card: *Gigabyte WINDFORCE V2 GeForce RTX 4090 24 GB Video Card  (kr23490.00 @ Proshop)
Case: Montech SKY TWO ATX Mid Tower Case  (kr1199.00 @ Proshop)
Power Supply: be quiet! Pure Power 12 M 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (kr2008.00 @ Proshop)
Total: kr38274.00
Generated by PCPartPicker 2024-02-23 08:55 CET+0100
for 60000 NOK
CPU: Intel Core i9-14900K 3.2 GHz 24-Core Processor  (kr7590.00 @ Proshop)
CPU Cooler: ARCTIC Liquid Freezer III A-RGB 69.9 CFM Liquid CPU Cooler  (kr1139.00 @ Proshop)
Motherboard: ASRock Z790 Taichi EATX LGA1700 Motherboard  (kr6201.00 @ Proshop)
Memory: G.Skill Trident Z5 RGB 96 GB (2 x 48 GB) DDR5-6800 CL34 Memory  (kr6269.00 @ Proshop)
Storage: Samsung 990 Pro 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (kr3790.00 @ Proshop)
Video Card: *Palit GameRock OC GeForce RTX 4090 24 GB Video Card  (kr24836.00 @ Proshop)
Case: Lian Li LANCOOL III RGB ATX Mid Tower Case  (kr1954.00 @ Proshop)
Power Supply: be quiet! Dark Power Pro 13 1600 W 80+ Titanium Certified Fully Modular ATX Power Supply  (kr5273.00 @ Proshop)
Total: kr60842.00
Generated by PCPartPicker 2024-02-23 08:56 CET+0100
why both?
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
48 minutes ago, filpo said:
For 40000 NOK
Total: kr38274.00
for 60000 NOK
Total: kr60842.00
why both?
I need 6+ monitors, and I assumed I need multiple GPU or something to make it work...
I reach out elsewhere I was able to get this list: https://pcpartpicker.com/list/Qhm7gB
CPU Cooler - ARCTIC Liquid Freezer III 56.3 CFM Liquid CPU Cooler
Motherboard - MSI MAG X670E TOMAHAWK WIFI ATX AM5 Motherboard
Memory: TEAMGROUP T-Create Expert 96 GB (2 x 48 GB) DDR5-6800 CL36 Memory (...
Storage - TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Power Supply - NZXT C1200 1200 W 80+ Gold Certified Fully Modular ATX Power Supply
Case Fan - Lian Li UNI FAN P28 92 CFM 120 mm Fans 3-Pack
I have to read up DeckLink, but from what I understood, that is better way of doing it.
This is good stuff for me to look into, as I don't yet understand the reason for change in parts. Why did you change the GPU, is it not better to have colder temperatures on the GPU? I very much appreciate the input. At the very least I learned that I can sort PCPartPicker for merchants :D!
PS: I intent to build a NAS for storage; as it is simply way cheaper (and more versatile for such need)
Edited by SaH
forgot gratitude...
oh for 6+ monitors then definitely
try this
Video Card: Intel Limited Edition Arc A750 8 GB Video Card  (kr3282.00 @ Proshop)
Case Fan: Lian Li UNI FAN P28 92 CFM 120 mm Fans 3-Pack  (kr978.00 @ Proshop)
Monitor: Asus TUF Gaming VG27AQ 27.0" 2560 x 1440 165 Hz Monitor  (kr3500.00 @ Proshop)
Monitor: Asus TUF Gaming VG249Q1A 23.8" 1920 x 1080 165 Hz Monitor  (kr2199.00 @ Proshop)
Total: kr75807.00
Generated by PCPartPicker 2024-02-23 09:57 CET+0100
won't make a huge difference in temps, the air cooled version will be fine
Current parts list
try this
Total: kr75807.00
Thanks a lot! Can't read all this now; but I will. Any particular reason for Intel CPU instead of the AMD? As I understand it they are fairly close in performance, but differ in power consumption: https://www.digitaltrends.com/computing/intel-core-i9-14900k-14600k-review/ (I have had some finicky experience with intel before. ( I remember a meme about how Intel and AMD CPU crash, and I believe I preferer AMD's way?)
Thanks 😄
better productivity than the X3D 7950 and better gaming performance if the 7950X3D has all CCd's enabled
Thanks 😄
if you want to go AMD go for the 7950x, not the X3D
CPU: AMD Ryzen 9 7950X 4.5 GHz 16-Core Processor  (kr6790.00 @ NetOnNet)
Motherboard: Asus TUF GAMING X670E-PLUS WIFI ATX AM5 Motherboard  (kr4008.00 @ Proshop)
Memory: G.Skill Trident Z RGB 96 GB (2 x 48 GB) DDR5-6400 CL32 Memory  (kr5211.00 @ Proshop)
Total: kr71756.00
Generated by PCPartPicker 2024-02-23 11:27 CET+0100
Current parts list
