Asking for help with fan curve for Ryzen 7 7800X3D
Solved by GuiltySpark_,
32 minutes ago, Muffin. said:DeepCool LS720
Its an AIO, so the fans are there to cool the water, not the CPU. The water changes temperature MUCH slower than the CPU so your "curve" can be more or less a flat line until say 85C. Heck I do this with my tuned 7800x3D on an air cooler. Flat 40% PWM until 85c then jumps to 60% PWM.
The worst thing in the world is the sound of fans ramping up and down in realtime to match the CPU temperature when there is no need.
