WiFi with Wired Network
Go to solution Solved by Lyons,
Nope.
my Gaming board has onboard WiFi but for now i'm using and ethernet Cable, i never used my WIFi so my question is, i know Wired is faster so can i use them both at the same time and will it make my Network cnx faster, because in theory it should right ?
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/155774-wifi-with-wired-network/
Nope.
Laptop Lenovo Thinkpad X220 - CPU: i5 2420m - RAM: 8gb - SSD: Samsung 830 - IPS screen Peripherals Monitor: Dell U2713HM - KB: Ducky shine w/PBT (MX Blue) - Mouse: Corsair M60
Audio Beyerdynamic DT990pro headphones - Audioengine D1 DAC/AMP - Swan D1080-IV speakers
https://linustechtips.com/topic/155774-wifi-with-wired-network/#findComment-2076542
Nope besides there is no way your internet is faster than gigabit ethernet
https://linustechtips.com/topic/155774-wifi-with-wired-network/#findComment-2076543
nope.
Build: Sister's new build |CPU i5 2500k|MOBO MSI h61m-p23 b3|PSU Rosewill 850w  |RAM 4GB 1333|GPU Radeon HD 6950 2GB OCedition|HDD 500GB 7200|HDD 500GB 7200|CASE Rosewill R5|Status online
Build: Digital Vengeance|CPU i7 4790k 4.8GHz 1.33V|MOBO MSI z97-Gaming 7|PSU Seasonic Xseries 850w|RAM 16GB G.skill sniper 2133|GPU Dual R9 290s|SSD 256GB Neutron|SSD 240GB|HDD 2TB 7200|CASE Fractal Design Define R5|Status online
https://linustechtips.com/topic/155774-wifi-with-wired-network/#findComment-2076755
OP: I dont think there is a way to do that. Sorry.
You'll get the speed you pay for. There are no magic tricks to speed up the internet for free...
Lol he is talking about network, not internet.
https://linustechtips.com/topic/155774-wifi-with-wired-network/#findComment-2076866
No, Windows does not support load balancing between two networks, you can only ever use one NIC at a time.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/155774-wifi-with-wired-network/#findComment-2076883
