I need help with choosing my PSU
Solved by Somerandomtechyboi,
10 minutes ago, Brimstone said:
I`am buying a RX 6600 and a Ryzen 5 4600G with 1TB SSD and is be quiet! 10 450W a good option or should i get a higher wattage PSU?
(sorry for mistakes its my first time posting here)
(Also no RGB 4 fans)
Country?
Budget?
Usecase?
4600g is already a horrible choice for the cpu so yea you probs need help with the entire build
As for the psu depends on price, though get a 500-650w unit atleast cause lower than that and value becomes non existent, though i would reccomend used instead due to 40-60$ being able to get you a used 750/850w rm(x) or equivalent psu thatd last you alot longer than some new 600w unit at the same price smply due to the higher wattage not to mention higher quality
