getting less than 10 mbps upload on 50mbps powerline ethernet adapters with a 100mbps network
Solved by kirashi,
13 minutes ago, P0LAR0 said:When downloading from steam or doing a speed test my download speed is extremely slow compared to expected speeds (see image below, left image is on the same network on my phone). I've had no issues like this before with with the same setup so I have no idea what's wrong here. My specs are as follows:
- Windows 11 Pro 22H2
- Gigabyte AX370m-DS3H motherboard
- AMD Ryzen 7 5700x at stock speeds
- 2x4gb Corsair Vengeance LPX ram and 2x8gb Silicon Power ram both at 2400mhz
- Gigabyte RX6600xt
- Crucial BX 240gb SSD as boot drive
- WD blue 500GB, Seagate Barracuda 500gb, Silicon Power 240gb m.2 drive and WD Green 240gb SSD as storage drives
- ThermalTake SMART Rgb PSU 550watt
Any help appreciated! -Polar
Temporarily bypass the PowerLine AV adapters by connecting the PC directly to the modem / router, then test speeds. If everything is normal during the test, that proves the problem is the PowerLine AV adapters, or more likely something inconsistently unreliable with your home's electrical wiring. Could be someone running a vacuum, microwave, or other high power draw device within the home. PowerLine AV is nice when it works, but otherwise can be a nightmare to troubleshoot.
