Decent 4.1/5.1 system under $150
da na
I'm looking to buy a decent 4.1 or 5.1 system that totals to under $150. Don't care if it's powered speakers or speakers I'd plug into an amp/receiver; I just want a system that sounds good. I am leaning towards a set from a brand known for specifically audio, like Klipsch or Bose, rather than a brand of computer peripherals, EG Logitech. I'd been looking at Altec Lansing's higher end from the mid 2000s as I've never had a Lansing (pre 2011) that didn't sound great, but I would like some other opinions instead of simply buying on brand loyalty.
It will be used in a 100 sq.ft room with the left/right speakers being within 4 feet of each other, thus me not caring too much about 4.1 versus 5.1.
I'll be using the system with my projector for movies and streams.
Thanks!
Thanks!
Do you truly want rear speakers?  A 2.1 or even just a 2 speaker setup is better from a sound quality for the money aspect.
Pair of powered monitors or the 2.1 from Klipsch are fantastic.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Awesome, thanks for the suggestion.
Now looking into used Klipsch monitors, the Micca OoO also looks nice.
Back in the day I had the klipsch promedia 2.1, I concur. They were great. And with such a small room, a little goes a long way.
