Compact disc copies do not work despite using various methods for creating them
Solved by Needfuldoer,
If you rip the disc to an ISO image, then mount that ISO as a virtual disc, does it work?
You could also try copying the contents of the disc 1-for-1 onto an external flash drive. Depending on how the software was written, it could be using absolute file paths to find all its parts. If that's the case, it won't work if you copy it to another folder like your desktop.
