240mm AIO for Intel i5-14600K
Debarghaya Mitra
Go to solution Solved by TatamiMatt,
35 minutes ago, Debarghaya Mitra said:
Thanks. Any other recommendations?
https://mdcomputers.in/deepcool-gammaxx-l240-argb-dp-h12cf-gl240-argb.html
https://mdcomputers.in/thermaltake-th240-v2-argb-sync-black-cl-w361-pl12sw-a.html
https://mdcomputers.in/deepcool-r-le520-bkammn-g-1.html
These 3*, very similarly priced
https://mdcomputers.in/ek-aio-240-d-rgb-3831109815830.html
This one is more than double the price, but a very good AIO, though i wouldnt spend that much more for the performance gains this might get you
Does your case allow for 280mm? That could also be an option to allow you to size up without going for a full 360mm
Edit: Upon checking the website provided, if 280mm is a posssibility, order from somewhere else the pricing on 280s is extortionate, the cheapest being 1.5x some of the 360mm AIOs
*added another
Bassically I want to buy an AIO for 14600K. AIO is required as I'm from India and you know whats summer means there.
I just want the cpu to turbo at all times. No air coolers please.
I am thinking of Cooler Master MasterLiquid 240L Core 240mm non ARGB
https://mdcomputers.in/cooler-master-masterliquid-240l-core-mlw-d24m-a17pk-r1.html
Any suggestion?
Any suggestion?
If youre able to shill out the extra and your case can fit it, go for this
https://mdcomputers.in/deepcool-r-le720-bkammn-g-1.html
360mm and MUCH better fans
also a higher pump rpm, not a whole lot, but every little counts
Also coolermaster AIOs arent as good in general, especially compared to deepcool, deepcool are doing very well in the AIO department
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
My case fits 240mm aio
Okay, definitely this one then, same pump speed but much better fans for an AIO, the Coolermaster ones leave...much to be desired
https://mdcomputers.in/deepcool-r-le500-bklnmc-g-1.html
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
*added another
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
These 2, very similarly priced
Yup supports 280 mm , And thanks.
Thermalright Frozen Notte
Thermalright Frozen Magic
Those are quiet and have strong pumps, but is replace the fans with one with high SP
Deepcool LS520 & LT520, very strong, not quite as quiet. You can still replace the fans for better performance (this is true of virtually any AIO).
Endorfy Navis F240 or F280 are strong and quiet, and should be available there.
Lian Li Galahad 2 Trinity Performance
There are more.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
