This is my current usage of my CPU, RAM, and GPU when playing Fortnite on high graphics, I want to play on Epic, but currently, I'm getting 80-100 fps in the game and my monitor runs on 165hz so I kinda want 165, my PC has:
GPU: Gigabyte GeForce RTX 3060 Ti Gaming OC D6X 8GB
CPU: AMD Ryzen 55600G with Radeon graphics
RAM: Corsair Vengeance RGB Pro 16GB (2x8GB) 3200MHz CL16 DDR4
I had the idea, that maybe my cpus Radeon graphics are being used, but I highly doubt that as my monitor is plugged into my GPU.
So the usage could be reading wrong, but then again with my GPU, i should be getting more fps than I currently do as when I first got my PC about a year ago I was easily getting 165 consistently as I had it locked at 165.
Does anyone have any ideas of why this could be happening?
https://linustechtips.com/topic/1551633-how-do-i-get-better-fps/
What is your actual usage with the game in focus and playing it? You can use MSI Afterburner to get those figures, and have an overlay running over the game.
I dont have that but with corsair ICUE it says the highest my GPU usage spiked to in 4% while I was ingame
What about CPU usage?
Also I personally doubt it was only 4%. It seems a bit low - like it's referencing integrated graphics instead of the RTX 3060, or it's just not an accurate reading.
And when I play a roblox game called Jailbreak on max graphics it does this
What am I supposed to be looking at?
Just now, HeHeNOPE said:
It actually shows the gpu usage of 20% in the roblox game but it doesn't for fortnite
What frame rate do you get in Roblox?
Is it possible for Fortnite to be using Radeon graphics? and other games like Roblox be using the GPU?
Do you have your integrated graphics enabled?
Idk
You'll have to go into BIOS to disable it. I doubt it's causing any issues if your monitor is plugged into your graphics card.
Your measurements should be taking place when playing the game - that is, when the GPU is rendering to the monitor, not while outside of the game.
Ig it could be reading wrong or smth but I still don't see why my fps has dropped so much recently, I was getting 120-165 fps in game and now its like 80 after I came back from a 2 week holiday, and yes I restart my PC weekly.
yeah, there's definitely something off with fortnite... so as per above check usage with hwinfo64 (just let it run in the background then you can check after playing the game for 10 minutes or so)
-Scott Manley, 2021
Does Fortnite allow you to see what you're using to render the game? I don't know anything about it.
